ZedBoard Hardware Design Problem in generating bitstream for Xillybus
  • Subscribers 361 subscribers
  • Views 321 views
mikgiak
mikgiak over 9 years ago
I'm using Xillinux/Xillybus with Zedboard. I've followed the documentation on how to integrate custom logic with the xillydemo.vhd but I experience problems in generating the bitstream and specifically the process stops on the implementation phase.
on the Xillybus forum said me to ask somewhere because the problem is not related to xillybus.
my aim is coprocessing. so I have an accelerator that has to comunicate with the FIFOs in the xillydemo.vhd.
the error message is this one :
There are registers with no clock. Please check your design. See Timing Summary Report.
And the problem is on the finite state machine of my accelerator. For example, this is the process for the registers :
   FSM_REG : process (clk)
      begin
        if (rising_edge(clk)) then
     if srst = '1' then
               CURRENT_STATE <= WAIT_READ_FIFO;
     else
               CURRENT_STATE <= NEXT_STATE;
     end if;
        end if;
    end process FSM_REG;
Any help?
Thanks a lot!
  • jafoste4
    0 jafoste4 over 9 years ago
    Hello mikgiak,
    I am going to ask that you post this question over at the Digilent forum as they are the main point of contact for educational support :
    https://forum.digilentinc.com/
    To get you going in the mean time, here is another forum post worth checking out :
    https://forums.xilinx.com/t5/Timing-Analysis/There-are-registers-with-no-clock-Please-check-your-design/td-p/670093
    --Josh
  • mikgiak
    0 mikgiak over 9 years ago in reply to jafoste4
    ok thanks!
    yes, I've already read about that post. similar problem but not exactly the same
