ZedBoard Hardware Design Integrating embedded design to xillybus
  • Subscribers 359 subscribers
  • Views 314 views
So I was able to successfully run the hdmi tutorial that I found in this link:
http://zedboard.org/reference-designs-categories/zedboard-hdmi-display-controller-tutorial-vivado-using-xilinx-vipp
The only problem is this works on embedded platform. I want to use this hdmi controller on Linux. Is there a way I can do that?
How do i generate clocks on xillybus Linux?
How do I integrate the block design on embedded to linux platform?
    Hello Jared,
    While Eli does respond to posts on the forum we do not use or support Xillybus Linux / Xillinux here. I would suggest that you spend some time looking at the documentation on the XillyBus website and ask questions specific to Xillinux there.
    http://xillybus.com/xillinux
    -Gary
