ZedBoard Hardware Design Using LED-s from Linux
  • Subscribers 360 subscribers
  • Views 437 views
xormaetxea10
xormaetxea10 over 9 years ago
Hello!
Im using a Zedboard, but not the "Out-Of-Box" Linux. Instead, i use the Ubuntu that Xilinx provides here:
http://www.wiki.xilinx.com/Ubuntu+on+Zynq
The problem is that I would like to use the command "write_led" that can be found in the Out-Of-Box configuration. How can I access to it? How can i install it it my new Linux?
Thank you in advance!
Xabi
  • jafoste4
    0 jafoste4 over 9 years ago
    Hello xormaetxea10,
    My suggestion would be for you to implement the GPIO Driver http://www.wiki.xilinx.com/Linux+GPIO+Driver
    Your goal is to just toggle the GPIO to turn the LED on and off correct? If so please refer to the example above.
    --Josh
  • jafoste4
    Hello xormaetxea10,
    --Josh
