ZedBoard Hardware Design HDMI and Audio IC
  • Subscribers 358 subscribers
  • Views 496 views
HDMI and Audio IC
Hi
  I am Designing my Own Board based on Zynq.I am Confused at the HDMI Controller and Audio Shown in ZED board Schematics. Question is In my Board i am using Zynq 7010 instead of 7020.SO where do i have to Connect Display and Audio Controller to Zynq?.Secondly are MIO are map able through Software for example MIO 15 D+ of usb can i replace the functionality in the GUI with another PIN?
Help will be appreciated
  • bhfletcher
    0 bhfletcher over 12 years ago
    The Analog Devices HDMI and Audio Codec chips can be placed on any of the PL I/Os. Keep them each isolated to one bank though. You'll then need to update your UCF to match the pinout that you choose. Note that the HDMI chip does support basic audio, but the codec will give you many more features.
    The MIOs are a different story. Those are somewhat programmable in that any one MIO may have multiple possible functions, but once you choose that function, the pinout should remain fixed. The MIO are mapped in software, but this is typically done in your FSBL and not modified after that.
    If you haven't already, you should view the Zynq Intro training at http://www.zedboard.org/support/trainings-and-videos. You should also go through the Building a Zynq Video Design from Scratch at http://www.zedboard.org/design/1521 and modify the device and pinout to what you want to do with your 7010.
    Bryan
    Thanks for the help Today i am Starting My PCB 12 Layers.My main Target is to add more features Like Precise Motion Control,Optical Interface,Sensor Fusion.
    Thanks For the help Again
