ZedBoard Hardware Design Create configuration part
  • Subscribers 360 subscribers
  • Views 519 views
marzhan
marzhan over 8 years ago
HeLLo!!! Please help me to find out the solution of this problem. Appropriate configuration memory part for the  Zedboad (xc7z020-1) I've chosen mt25/ql512 as I assume these group matched ones. When I wanted create configuration file
write_cfgmem -format MCS -size 512 -interface bpix16 -loadbit "up 0x0 /
C:/Users/Administrator/Desktop/vivado/REPORT.runs/impl_1/design_1_wrapper.bit" /
I got following errors:
ERROR: [Bitstream 40-46] File / cannot be opened for input.
ERROR: [Writecfgmem 68-7] Could not load bitfile /.
ERROR: [Common 17-39] 'write_cfgmem' failed due to earlier errors.
I have tried to increase and decrease the memory size and change the memory parts but still there is same error.
Thanks in advance.
  • jafoste4
    0 jafoste4 over 8 years ago
    Hello Marzhan,
    Please ask your question over at Digilent as they are the main point of contact for educational support.
    Thank you,
    Josh
