ZedBoard Hardware Design Noise in Line out
  • Subscribers 358 subscribers
  • Views 346 views
Noise in Line out
I configured the audio codec through I2S in zedboard after referring zynq book tutorial. I am inputting audio into the zedboard through LineIn from PC and simply writing it back to LineOut. But I am noticing a lot of noise in LineOut. Even when there is no sound playing in PC, still there is some constant noise coming out of LineOut in zedboard. What should I do?
  • drozwood90
    0 drozwood90 over 11 years ago
    Hi there,
    It sounds like you have a ground loop between your PC and your Zedboard.  Due to the complexity in how a PC is setup, I have seen this happen on quite a few audio related setups.
    The solution that has typically solved my problem is getting a ground loop isolator.  Cheaper versions of these can be found at most electronics stores for not too much money.
    There is also a professional level one on Avnetexpress.com :  721-0001-000
    My suggestion is to get a cheap one to ensure this is the issue.  When you determine that it is, go ahead and purchase a higher quality one.
    --Dan
