ZedBoard Hardware Design HOW TO ACCESS DATA FROM DDR of PS side from PL PART
  • Subscribers 359 subscribers
  • Views 4507 views
hai,
im need to access data from DDR of PS side through PL part so that i can process according to my design.
already the DDR is configured in PS side and now i just required to read and write from PL side .
please kindly give solution for this problem
thanks & regards
sivasankar
    Take a look at the Avnet Zynq Hardware Speedway Tutorial for an understanding of how the PL portion of the Zynq device can access the PS DDR memory via AXI GP ports using PS or PL DMA or via a High Performance Master in the PL using PL DMA:
    Developing ZynqRegistered-7000 All Programmable SoC Hardware (Vivado 2013.3 and 2014.4.1)
    Then you can take a look at the examples in UG1165, the Zynq Embedded Design Tutorial:
    http://www.xilinx.com/support/documentation/sw_manuals/xilinx2015_1/ug1165-zynq-embedded-design-tutorial.pdf
    Jeff Johnson also has a good tutorial on using AXI DMA:
    http://www.fpgadeveloper.com/2014/08/using-the-axi-dma-in-vivado.html
    and Adam Taylor also addresses using AXI DMA in his blog:
    http://forums.xilinx.com/t5/Xcell-Daily-Blog/Adam-Taylor-s-MicroZed-Chro...
    -Gary
