ZedBoard Hardware Design What is the point of the 1-1 AXI interconnect in ADV7511 reference design?
  • Subscribers 359 subscribers
  • Views 332 views
henry10210
henry10210 over 11 years ago
Hello, I have a working HDMI design that has changed little from the HDMI design in "Ubuntu on Zedboard" reference design.  I am now drilling down to understand the video portion of the design.  The PS --> ADV7511 high speed data path starts from the PS7's S_AXI_HP0 port and then goes through an AXI interconnect (instance name axi_hdmi_interconnect) in a 1-1 fashion: there is no other master or slave on this interconnect.
I don't understand why this interconnect is necessary.  Can someone please explain, or point me to a reference that does?  Thank you very much for reading.
w/ regards,
Henry
  • albertabeef
    0 albertabeef over 11 years ago
    Henry,
    The Zynq Processor System (PS7) has AXI3 interfaces.  Since all programmable logic (PL) designs and IP use AXI4 interconnect, a simple point to point connection will still have an AXI interconnect module to implement the protocol conversion.
    If you open the hierarchy of the axi_hdmi_interconnect module, you will see the AXI Protocol Converter module.
    Mario.
  • henry10210
    0 henry10210 over 11 years ago
    Thanks you for the explanation, I guess you are referring to the s00_couplers under axi_hdmi_interconnect.
