ZedBoard Hardware Design Ethernet not working in PL part!
  • Subscribers 359 subscribers
  • Views 423 views
I am trying to implement a soft EMAC (100Mbps) and using FMC -ISMNET card from Avnet . I have done the connections for TX and RX side including reset, powerdown etc. as per the documentation.
I am running loopback test using the peripheral test application generated in SDK. The application hangs on loopback test.
Anyone having suggestion on this....
Ved
    Just want to update that  Tx side i can see data packets being sent but on Recieve side ,no response is there in the loopback test.
    Ved
  • bhfletcher
    0 bhfletcher over 12 years ago
    Which soft emac are you using?
    Bryan
    0 Former Member over 12 years ago in reply to bhfletcher
    Hi
    Thanks for your feedback. Actually we are using axi_ethernetlite version 1.01b
    Ved
