ZedBoard Hardware Design Connecting Ultrasonic HC-SR04 to Zedboard
  • Subscribers 360 subscribers
  • Views 719 views
Hi ,
I want to connect Ultrasonic Ranging Module HC - SR04
with my zedboard.
I am using pmod JB1 and JB2 pin for trig and echo.
From HC-SR04 data sheet it is known that the two outputs from module is TTL 5V signal.
Please suggest me will it cause nay hardware failure to my zedboard.
https://docs.google.com/document/d/1Y-yZnNhMYy7rwhAgyL_pfa39RsB-x2qR4vP8saG73rE/edit
    The Zedboard I/O is NOT 5 volt tolerant, so you will need to provide some sort of level translation or signal conditioning before connecting those signals to JB1 and JB2. Otherwise you may damage the Zedboard.
    -Gary
  • zedhed
    0 zedhed over 10 years ago
    Hi Gaurav,
    Gary is correct that the Zynq device on ZedBoard is not 5V tolerant.
    I have used an implementation of the circuit described on this page to connect an HC-SR04 up to MicroZed + I/O Carrier:
    http://electronics.stackexchange.com/questions/97889/is-there-any-bidirectional-5v-3-3v-level-shifter
    It is basically a 5V to 3.3V level translator which uses an inexpensive MOSFET to adjust the signal voltage level from 5V to 3.3V needed on your TRIG input to Zynq.
    We used this exact circuit as part of an exercise for Avnet Tech Games 2014 Digital Design Dilemma:
    http://www.avnettechgames.com/activegame/4751
    We also later re-used that ultrasonic sensor and level translator in our Sensor "Fusion" Industrial IoT platform shown at X-fest:
    http://xfest2014.com/exhibit/sensor-fusion-microzed%E2%84%A2
    You can contact me directly if you are interested in more information and I can share the level translator schematic we used for this with you.
    -Kevin
