ZedBoard Hardware Design Linux source from github
  • Subscribers 364 subscribers
  • Views 1149 views
100aditya
100aditya over 9 years ago
      I am trying to download the linux source code from https://github.com/Xilinx/linux-xlnx. As there are many tags available at this repository so , Can anybody please  tell me which is the stable and latest "tag" for this on this website for ZedBoard.
Regards
Aditya
  • jafoste4
    0 jafoste4 over 9 years ago
    Hello Aditya,
    Unfortunatly we do not manage that github account. Please ask this question over at the Xilinx forum.
    https://forums.xilinx.com/
    Josh
    0 e14 Contributor over 9 years ago in reply to jafoste4
    Josh is correct, but typically you should match a release tag to the version of Vivado you are using.  If you scroll through the tags, you will see one that matches the 2016.2 release, for example.  That would be the latest stable release for that version of Vivado and PetaLinux tools.  2016.3 will probably be released soon, since the hardware tools went public not long ago.
    Ron
  • zedhed
    0 zedhed over 9 years ago
    Hi Aditya,
    Josh is correct, the Xilinx forum is the correct place to ask this question as we have no control over the releases there.
    I have found that you are usually safe sticking to the major release tags.  For example, using "xilinx-v2016.2" should be okay for you to use.
    -Kevin
  • 100aditya
    0 100aditya over 9 years ago
        Thanks you all for advice.
    Regards
    Aditya
  • pmckinnon
    0 pmckinnon over 9 years ago in reply to e14 Contributor
    Hi, any ETA on 2016.3 BSP?
  • jafoste4
    0 jafoste4 over 9 years ago in reply to pmckinnon
    Hi Pmckinnon,
    Xilinx is the one who is in charge of the Zedboard BSP. You can find the 2016.3 Zedboard BSP on their website at
    https://www.xilinx.com/support/download/index.html/content/xilinx/en/downloadNav/embedded-design-tools.html
    labeled "ZED BSP".
    --Josh
