ZedBoard Hardware Design Simple AMP Running Linux and Bare-Metal System on Both Zynq SoC Processors
  • Subscribers 359 subscribers
  • Views 546 views
   I am running cpu0 on linux and cpu1 on Bare metal in Zed board.While i copied the boot.bin and required files (6 files) to SD card. while I switch ON the Zed-board,booting process is not loading,Even it doesn't shows any error also...
http://www.xilinx.com/support/documentation/application_notes/xapp1078-amp-linux-bare-metal.pdf.
    A similar topic is already opened here:
    http://www.zedboard.org/content/amp-running-linux-and-bare-metal-system-both-zynq-soc-processors
    I am trying to utilize both cpu0 and cpu1 on zed board.
    Using the document xapp1078,that document having operation of cpu0 on linux and cpu1 on bare-metal.
    First, I downloaded the following generated files and copied to SD card them.
    I took the files from your github account https://github.com/vcesson/xapp1078_z
    <SD card>
    - BOOT.BIN
    - devicetree.dtb
    - uImage
    - uramdisk.image.gz
    - rwmem.elf
    - softUart.elf
    After I switched on Zed Board,booting process has to start, and booting process(cpu0) was started,
    but cpu1 was not started.
    zynq > /mnt/rwmem.elf 0xffff8000
    0x00000000ffff8000 = 0x00000000
    zynq > /mnt/rwmem.elf 0xfffffff0 0x18000000
    "0xffff8000"address remains unchanged "0x00000000".
    Please provide a solution as soon as possible.
