ZedBoard Hardware Design zedboard PMOD JC differential no output
  • Subscribers 359 subscribers
  • Views 625 views
exds75
exds75 over 8 years ago
Hi Zedboard,
I am testing PMOD JC differential output.
In vivado I implement a AXI-GPIO, then modify the wrapper to output a pair of sinalP/sinalN with OBUFDS primitive
OBUFDS #(
      .IOSTANDARD("TMDS_33") // Specify the output I/O standard
   ) OBUFDS_inst1 (
      .O(sinalP),     // Diff_p output (connect directly to top-level port) (p type differential o/p)
      .OB(sinalN),   // Diff_n output (connect directly to top-level port) (n type differential o/p)
      .I(gpio_tri_o)      // Buffer input (this is the single ended standard)
xdc file as below,
set_property -dict {PACKAGE_PIN AB7 IOSTANDARD TMDS_33} [get_ports sinalP]
set_property -dict {PACKAGE_PIN AB6 IOSTANDARD TMDS_33} [get_ports sinalN]
After vivado generate/output bitstream, I toggle GPIO value in SDK. However, JC PMOD simply has no output at all.
From other posts, seems ppl have similar problem on PMOD differential outpus,
http://zedboard.org/content/zynq-7020-bank-33-differential
https://forums.xilinx.com/t5/Embedded-Processor-System-Design/LVDS-LVDS-25-Problem-on-Zynq/td-p/645481
http://zedboard.com/content/problem-obufds
Please advise, Thanks in advance
Mike
