ZedBoard Hardware Design Load QSPI via TFTP
  • Subscribers 359 subscribers
  • Views 587 views
Load QSPI via TFTP
I am trying to load a full petalinux in QSPI of the zedboard rev. D. I have a tftp server running on my host-pc and I am able to run petalinux on the zedboard from the host pc with "run jtagboot". My question is how do I copy all the files (boot.bin; devicetree.dtb; uImage and uramdisk.image.gz) to QSPI?
thanks in advance
  • zedhed
    0 zedhed over 12 years ago
    Hi egbertk,
    It should be possible to do this update using TFTP, and if you configure PetaLinux to boot from the primary flash, it should build some update macros like update_boot, update_dtb, updated_kernel, and update_jffs2 which can be used to update those flash partitions.
    Xilinx UG983 covers the use of some of these macros:
    www.xilinx.com/support/documentation/sw_manuals/petalinux2014_2/ug983-petalinux-firmware-upgrade.pdf
    Take a look at that document and see if that answers your questions.
    -Kevin
