ZedBoard Hardware Design Integration of TI WILINK8
  • Subscribers 359 subscribers
  • Views 394 views
xiaole
xiaole over 9 years ago
Hi!
I'm now integrating TI wilink8 to my Zedboard and I stuck with some problems.
Since the provided scripts are for microzed I try to follow the script manually with some modifications.
Here are my steps:
1. Clone the build-utilites from repo and init it (Just follow the script)
cd ~/Documents
git clone git://git.ti.com/wilink8-wlan/build-utilites.git
cd build-utilites
git checkout tags/ol_r8.a9.14
cp setup-env.sample setup-env
./build_wl18xx.sh init
2. Modify the kernel config (.config)
3. copy the driver from step 1 to kernel src
  rm -r drivers/net/wireless/ti/*
  cp -r ~/Documents/build-utilites/src/driver/drivers/net/wireless/ti/* drivers/net/wireless/ti/
  4. I skip the kernel patch part now, and just build the kernel.
  Since I don't think the kernel version I use is fitting the patch it provides. (build successfully)
  Here comes the problem, I have no idea how to modify the default dts file. I have read the provided microzed device tree, but still have no idea how to make them fit the Zedboard.
  Also, I check the following guide.
  http://processors.wiki.ti.com/index.php/WL18xx_Platform_Integration_Guide#Board_Device_Tree
  After I check both the provided microzed dts and the guide, I totally confused about what should I modify in Zedboard's device tree, since they are quite different.
  Could any one please give me some advice about the problem?
  Thank you in advance!!
  • jafoste4
    0 jafoste4 over 9 years ago
    Hello Xiao,
    Please as your question over at the TI forum.
    https://e2e.ti.com/
    --Josh
