ZedBoard Hardware Design Boot problems
  • Subscribers 360 subscribers
  • Views 870 views
Boot problems
screenshifter
screenshifter over 7 years ago
Boot seems to be unstable. Boot with SD card sometimes fails at all, with flash memory zynq reboots automatically after such fails. But moreover successfull boots are rare, mostly signals are spurious or constant. Is it connected with lack of fpga resources or how can i cope with this?
Zedboard rev D.
Estimated resources and timing summary are shown on this image:
/sites/default/files/u197791/resources_0.png
  • jafoste4
    0 jafoste4 over 7 years ago
    If your having issues boothing reliably from SD Card it is most likely either your fpga or your application code. Does evyerhting work as expected when booting from Jtag?
    --Josh
  • screenshifter
    0 screenshifter over 7 years ago in reply to jafoste4
    Thanks for answer, JFoster. Forgot to say booting from JTAG has the same issue.
  • jafoste4
    Hi Screenshifter,
    Do you have any time errors in your design? What do your constraints look like?
    --Josh
  • screenshifter
    Yes, i have time errors, illustrated here: /sites/default/files/u197791/resources_0.png
    I have one constrainted clock, which looks like this:
    create_clock -name rx_clk       -period  16 [get_ports rx_clk_in_p]
    Other clocks are created using this with Clocking Wizard IP or taken from ZYNQ7 Processing System.
    Also didn't tell i have baremetal application, if this is important at all.
  • jafoste4
    Hey Screenshifter,
    If your having booting problems I would suspect the timing errors in your hardware platform are the cause. Having a baremetal application shouldn't have any affect. Pelase correct this.
    --Josh
  • screenshifter
    Thanks, JFoster, i'll try to get rid of timing errors.
