ZedBoard Hardware Design ZedBoard compatibility with FMC 1000 Base-T Ethernet Card
  • Subscribers 359 subscribers
  • Views 799 views
Hi.
I'm interesting in ZedBoard for my homebrew projects.
Could you help me with one question. Is ZedBoad has a full compatibility with this FMC card TB-FMCL-GLAN-B (http://solutions.inrevium.com/products/fmc/peripherals_debug/index.html)?
    Up
    Still actual question.
    We have not verified this board on the ZedBoard, but from a review of the specifications it looks like it should work. The ZedBoard FMC is a full LPC implementation and the Zynq Ethernet MACs do support GMII interface through the EMIO interface. The I/O on the ZedBoard FMC interface  span two I/O banks, so you will need to pay close attention to your timing.
    -Gary
    Just to keep you inform.
    We make it up and running.
    I would like to use the TB-FMCL-GLAN-B with the zedboard under xillinux operative system. If you had any expertise in this issue, I would appreciate any help.
