ZedBoard Hardware Design ZedBoard-HDMI Display Controller Tutorial
  • Subscribers 362 subscribers
  • Views 1166 views
yangtuzi
yangtuzi over 9 years ago
I do the lab  based on <ZedBoard HDMI Display Controller Tutorial> on my ZedBoard.
The Tutorial required software is vivado 2013.4,but my vivado is 2014.4.
When I step by step follow the Tutorial to step 20(page 22 on documentation),do Validate Design.Some warning appear:
The input pins (listed below)are either not connected or do not have a source port,and they don't have a tie-off specified.
Please check your design and connect them if needed:
/zed_hdmi_dispaly/axi_vdma_0/axi_resetn
etc..
  • jafoste4
    0 jafoste4 over 9 years ago
    Hello Yang,
    My suggestion would be for you to download and install the 2013.4 tool set and see if that solves your problem.
    Josh
  • yangtuzi
    0 yangtuzi over 9 years ago in reply to jafoste4
    I have solved it.I get Hardware_Evaluation license for v_cresample,and load the licesen.And the (1)Reset output Products;(2)Generate Output Products;(3)Reboot Vivado.Finally.generate the bit succesfully.Thankyou!
  • aynilian
    0 aynilian over 8 years ago in reply to yangtuzi
    Hi Yangtuzi,
    I got the hardware evaluation license for v_cresample too, but I'm using the Vivado 2016.3. I re-did the block design based on the original flow using the latest IPs. I have it compiled and can see the VDMA and the Video Stream, and the Video outputs only on the ILA, but I can't seem to see it coming out of the FPGA. Any ideas?
