ZedBoard Hardware Design FSBL SD start error
  • Subscribers 360 subscribers
  • Views 706 views
FSBL SD start error
Iwant to start a standalone elf on the board,
I have imaged three files(fsbl elf, bit, standalone elf )into a bin file , and the  mode is  setted at SD_START ,  it doesn't work,
If I replaced the fsbl elf file(generated from defualt set) with the zedboard fsbl elf file ,
it works,
and now I don't why the fsbl file (generated from the default parogramme) doesn't work
who can help me ,
thanks very much!!
Xilinx First Stage Boot Loader
Release 2015.2tMar 11 2016-15:12:41
Devcfg driver initialized
Silicon Version 3.1
Boot mode is SD
SD: rc= 0
SD: Unable to open file BOOT.BIN: 3
SD_INIT_FAIL
FSBL Status = 0xA009
This Boot Mode Doesn't Support Fallback
In FsblHookFallback function
  • zedhed
    0 zedhed over 10 years ago
    Somehow this got posted as a duplicate thread of this one here:
    http://zedboard.org/content/fsbl-sd-start-error-0
    If this was accidental, can you please delete this thread and I will respond on the other one?
    -Kevin
    0 Former Member over 10 years ago in reply to zedhed
    I find SD initialized ,but partition header load failed
    Release 2015.2tMar 12 2016-16:31:50
    Silicon Version 3.1
    Boot mode is SD
    SD: rc= 0
    SD Init Done
    Flash Base Address: 0xE0100000
    Reboot status register: 0x60000000
    Multiboot Register: 0x0000C001
    Image Start Address: 0x00008000
    Partition Header Offset:0xEB008641
    Partition Count: 14
    Invalid Partition Count
    Partition Header Load Failed
    FSBL Status = 0xA00E
