ZedBoard Hardware Design Zedboard Ethernet Performance
  • Subscribers 360 subscribers
  • Views 628 views
We have done some performance tests on the ethernet connection on the zedboard.  Linux identifies the ethernet port as being 1000 BT but the performance tests show a transfer rate at only 4.7 Mbytes per second.  Poor for even 100 BT.
Is the zedboard capable of transfer rates that would be associated with a 1000 BT link?
    Performance is usualy not even 1/2 the link speed, at best.  It only gets slower from there, depending on the memory, and what else you need to do (with the processor).
    0 Former Member over 12 years ago in reply to Former Member
    Thanks for the reply.  I agree with you that the link speed is usually much slower but at 4.8 MBytes or 38 Mbits/sec that isn't even close to half the 100 Mbit/sec line rate of 100 baseT not to mention that the zedboard is supposed to be a 1 Gbit/sec link which makes the 38 Mbits/sec through put of this board look like complete crap.
    I suspect that the Ethernet driver is not using DMA.
  • zedhed
    0 zedhed over 12 years ago
    Hi wlcraig,
    Have you taken a look at our "Open Source Linux Ethernet Performance Test Tutorial" posted on the Reference Designs page?
    http://www.zedboard.org/design
    -Kevin
