ZedBoard Hardware Design Writing user data to Flash memory
  • Subscribers 360 subscribers
  • Views 540 views
siseoth
siseoth over 9 years ago
I am trying to write some specific data to the onboard flash to be able to read them without using Linux. According to http://zedboard.org/content/writing-file-flash-memory-and-reading-it-pspl, I have seen the examples Xilinx provides and tried to use the code in my application. My problem is that when running it the example test fails. I have pinpointed that it reads the data but it's not the same as written. In fact it is all "1" written. I don't know if I have done something wrong along the way or if I have missed a small detail. I would like your guidance on this issue.
Thank you.
  • jafoste4
    0 jafoste4 over 9 years ago
    Hello Siseoth,
    Did you try going through the Developing Zynq Software Speedway lab 11 like Kevin suggested in the post your referenced?
    I'm not sure why your encountering the issues with the Xilinx examples. My suggest would be to post over at the Xilinx forum as they are the expert in regards to the examples your attempting to run.
    https://forums.xilinx.com/
    --Josh
