ZedBoard Hardware Design FMC-LPC connection
  • Replies 7 replies
  • Subscribers 360 subscribers
  • Views 1272 views
FMC-LPC connection
Hi, I'm an unexperienced Zedboard user. I want to connect to the FMC-LPC connector, and route those signals to another board. How can I do it? Possibly using components that I can solder by hand. Thank you.
  • jafoste4
    0 jafoste4 over 9 years ago
    Hello Lucabe,
    Please ask your question over at digilent as they are the main contact for educational support.
    --Josh
    0 e14 Contributor over 9 years ago in reply to jafoste4
    Hello Josh,
    thank you for your reply, I have forwarded my question to digilent. In the meanwhile, could you give me some quick hints on how to solve my problem? that would be really appreciated.
    /Luca
  • jafoste4
    Hi Luca,
    It seems you have gotten a response over at digilent https://forum.digilentinc.com/topic/3375-zedboard-fmc-lpc-connection/#comment-12369
    It depends on how you are planning on communicating with the other board. Are you going from FMC to FMC, or are you trying FMC to ethernet communcation. It really depends.
    --Josh
    Hi Josh,
    I need to use 45 I/O, so I thought to use the FMC connector that has 68 I/O. I simply need to route these signal to another board, somehow, and then route them individually.
    Thanks a lot for your help!
    /Luca
  • jafoste4
    Hello Lucabe,
    Here is a list of FMC Cards that Xilinx offers that may suit your application. Make sure to use a LPC FMC Module.
    https://www.xilinx.com/products/boards-and-kits/fmc-cards.html
    --Josh
    Hi Josh,
    thanks for the tip, but I don't find a board that suits me. Do you think is too crazy to design my own board?
    Cheers,
    /Luca
  • jafoste4
    Hello Lucabe,
    Unless you have prior experience in designing your own boards, I would suggest that you do not. The easiest way would be to find a proven board that works for what you are trying to do.
    --Josh
