ZedBoard Hardware Design PmodOLEDrgb doesn't work on Zedboard
  • Subscribers 359 subscribers
  • Views 419 views
dutacristinaloredana
dutacristinaloredana over 9 years ago
I tried to make the tutorial "Getting the PmodOLEDrgb to work on Zybo" available on the instructables.com website to work for Zedboard.
When I program the FPGA and run the application nothing gets displayed on the OLEDrgb Pmod.
Are there any setup steps that need to be done?
I have no error messages and no warnings.
Best regards,
Cris
  • bhfletcher
    0 bhfletcher over 9 years ago
    Cris,
    For future reference, it is not necessary to post the same question in 4 different places. I have deleted your other 3 identical requests.
    From the Avnet perspective, we didn't create the PmodOLEDrgb Pmod, nor did we write the Tutorial to get it working on Zybo. I expect both those things were done by Digilent, who is also a ZedBoard partner. Have you already asked these questions to Digilent?
    In general, when porting a design from one board to another, some recommendations are:
    •   Make sure you match the tools version for which the original design was written
    •   Be very careful in modifying the Constraints for the new board as the pin locations very likely changed
    •   If updating a design, make sure you also copy any custom IP that was provided with the original design in a repository that may have been located outside the project directory.
    •   An updated design must have the board file reference modified to the new board
    I hope that helps point you in the right direction. Perhaps other community members have successfully migrated this board to ZedBoard and will comment.
    Bryan
