ZedBoard Hardware Design SciLab / XCos Support on Zedboard
  • Subscribers 363 subscribers
  • Views 770 views
tli28762
tli28762 over 9 years ago
Hi, I want to know if the Scilab/XCos support for the Zedboard is the same one that the Microzed has.
I'm interested in doing Hardware-in-the-loop with one of these and the Zedboard hardware seems more attractive but I want to know if it has the same support for Scilab that the Microzed has.
  • jafoste4
    0 jafoste4 over 9 years ago
    Hello Tli28762,
    Unfortunatly we do not support Scilab/XCos. I suggest that you find a forum that supports that open source software and ask your question there.
    Here is a good place to start looking: https://www.scilab.org/scilab/about
    --Josh
  • mbrown
    0 mbrown over 9 years ago
    MicroZed and ZedBoard have a lot of similarities. If you're ambitious, you could have a look at their open-source code for MicroZed and try to adapt to ZedBoard.
    Why is ZedBoard more attractive? MicroZed + FMC Carrier is less expensive. If you need HDMI, you can add the AES-FMC-HDMI-CAM module. Might be easier than trying to port the SCILABs plugin.
    /Matt
  • tli28762
    0 tli28762 over 9 years ago in reply to mbrown
    Thank you guys, that's the kind of answer I was hoping for. Have a nice day.
  • ikellymo
    0 ikellymo over 8 years ago
    Hi, can you please provide details about what you mean for microzed Scilab/Xcos support? I haven't found any references yet. Thank you!
