ZedBoard Hardware Design DRAM ACCESS
  • Subscribers 358 subscribers
  • Views 347 views
DRAM ACCESS
I tried to have a read and write on the DRAM before by AXI MASTER BURST.
which I couldnot! And cannot understand why!
I mean I am quite sure about the functionality of my code reading and writing in burs mode.
but it just work when I use single beat mode I thought it did not write in dram because of coherency issues. But when I try reading in burst it did not work either.
I even thought of address alignment. But as the DRAM addresses starts at 0x00000000 and I am going to read 64bits
I think if I put the length argumant in the function for ex 16, for 2 bursts. It should be work.
any way does not work at all!
then I remeber I tried using DMA for reading and writing.
Does anyone have idea, what are the mai differences of these two?
how much data DMA reads each time and is it a pre defined size?
many thanks
  • bhfletcher
    0 bhfletcher over 10 years ago
    This was a good question to post on the Xilinx forums since it is specific to Zynq and not one of our boards. Looks like you did that, so I'll share a few links for others.
    https://forums.xilinx.com/t5/Zynq-All-Programmable-SoC/axi-master-burst-writing/td-p/648722
    https://forums.xilinx.com/t5/Zynq-All-Programmable-SoC/How-Do-I-Perform-an-AXI-Burst-in-Software/td-p/592502
    Bryan
