ZedBoard Hardware Design Using FMC for massive GPIO breakout
  • Subscribers 360 subscribers
  • Views 1174 views
david.radakovits
david.radakovits over 8 years ago
Hi!
I'm not sure if this is the right forum for my question and also I'm not completely sure if I got the underlying topic right.
We want to use the FPGA on the Zedboard to control some other hardware, which has an interface with quite a lot of pins (>64, input and output all together).
Can the FMC be used to provide such an amount of GPIO?
http://zedboard.org/sites/default/files/documentations/ZedBoard_HW_UG_v2_2.pdf
This document under 2.9 says that FMC provides 68 single ended I/O, but I'm not sure were to find the information of which pin is connected where on the Zedboard.
Thanks a lot!
  • jafoste4
    0 jafoste4 over 8 years ago
    Hello David,
    You can find all the pin locations in the Zedboard Master XDC Rev C/D v3 located at this link:
    http://zedboard.org/support/documentation/1521
    --Josh
  • iam_electronic
    0 iam_electronic over 8 years ago
    Additionally, a description of FMC LPC pinout is here:
    https://fmchub.github.io/appendix/VITA57_FMC_HPC_LPC_SIGNALS_AND_PINOUT.html#lpc_pinout
    The Zedboard connector utilizes all 68 user data pins and 4 clock pins according to the standard.
