ZedBoard Hardware Design How to access GPIOs at highest speed in ZYNQ
  • Subscribers 360 subscribers
  • Views 1502 views
vinitk99
vinitk99 over 8 years ago
I am new to ZYNQ based development. So, I need help in understanding basics of PS-PL interface, its maximum speed and working.
I want t access the GPIOs of the Zed board at a very high speed (min. 100 MHz - max ???). Which interface can help me achieve this (please also mention max. speed)?
I have tried using AXI bus as well as EMIO and used the Arduino headers as GPIOs. But the maximum write/read speed I have achieved is ~4 MHz (for both the interfaces). I don't understand why is speed restricted to 4 MHz.
I have referred ug-585 and user manual for reference.
-Vinit
  • jafoste4
    0 jafoste4 over 8 years ago
    Hello Vinit,
    Did you every go through the developing zynq hardware speedway?
    --Josh
  • vinitk99
    0 vinitk99 over 8 years ago in reply to jafoste4
    Hi Josh,
    Thank you for your reply.
    Yes, I went through the speeday tutorials by Avnet.
    And understood various options for accessing GPIOs from there.
    Is there something I am missing here?
    -Vinit
  • jafoste4
    Hello Vinit,
    Please take a look at issue 10 and 11 in the microzed chronicles http://zedboard.org/content/microzed-chronicles
    --Josh
  • vinitk99
    Hi Josh,
    Thank you for sharing the link.
    I looked at the issues 10 and 11 and my implementation was exactly what was suggested in the microzed chronicles.
    As mentioned earlier, I was able to toggle GPIO using EMIO and AXI bus, but the speed of GPIO read and write is very low (~4 MHz).
    This is just an initial stage of my project and I need to read and write to GPIOs at least 100 MHz.
    So, I am trying to understand what is restricting EMIO and AXI bus speed. And find a way to use the GPIOs at higher speed.
    As of now, this is what I am doing in the code:
    while (1){
    XGpioPs_WritePin(&psGpioInstancePtr, iPinNumberEMIO, 0x0);
    XGpioPs_WritePin(&psGpioInstancePtr, iPinNumberEMIO, 0x1);
    and the generated output is a 4 MHz square wave.
    - Vinit
