ZedBoard Hardware Design Failed the execution on Zedboard
  • Subscribers 359 subscribers
  • Views 775 views
I have a VHDL model in Simulink. My simulation runs good, the results are OK. When I execute my model on target, the result isn't OK but I don't know how to resolve it. How can I watch the simulation on real time? I don't know where is the problem.
Thanks.
    how can I know what is the ARM version?
    Thanks.
    Take a look at the Zynq Technical Reference Manual, UG585:
    http://www.xilinx.com/support/documentation/user_guides/ug585-Zynq-7000-TRM.pdf
    -Gary
    Hello Gary,
    first, thank you for you information and help. However, I don't find in your document the solution to my problem.
    I have a Simulink model what run OK when I simulate it, I don't have any warning o error message. I use HDL Workflow Advisor because I want to execute my model on the target. I can execute all steps, but if I try to execute the Generate Interface Model on the target, the results is very different to the simulation model. I don't have any warning or error and I don't know where is the problem. I've tried to change the configuration with different solver modes but it isn't OK.
    I can execute other models like the blink leds or the data capture. So, I think I have good configured the target.
    Can you help me? Do you know what would be my problem?
    Thanks.
    The question you are asking is really a Xilinx software tools issue. I don't know the answer. You will probably find a broader and more knowledgable audience for this question on one of the Xilinx Community Forums:
    https://forums.xilinx.com/
    I will note that from one of your earlier posts it looks like you are still using the outdated Xilinx ISE tool suite. If this is true I would suggest moving your project to the more current Vivado tool suite. The current version is Vivado 2016.2. You are more likely to get answers for the current tools.
    -Gary
    thank you for your help, I've solved my problem. I found the problem in my model.
