ZedBoard Hardware Design Tutorial xapp1079. Can't use declared template
  • Subscribers 359 subscribers
  • Views 281 views
jesusmgonzalez
jesusmgonzalez over 12 years ago
I'm following the step-by-step tutorial to start both processors and comunicate them:
http://www.wiki.xilinx.com/XAPP1079+Latest+Information
and its pdf user guide documentation:
http://www.xilinx.com/support/documentation/application_notes/xapp1079-amp-bare-metal-cortex-a9.pdf.
Setting the directories as indicated, I correctly generate the bitstream from XPS, using the last software version from the above link (14.6).
The problem arises when I start the Xilinx SDK, and include as repository the modified BSP (as indicated in the user guide). Once I want to create a new Application Project, I follow the steps, introducing its name and selecting the corresponding processor, but when I follow to the next window/step, where I can choose between different templates (Hello World!, FSBL,etc), the template named "Zynq FSBL for AMP" is not included in the list.I've checked the paths and directories several times.
Does someone know how to get it?
    see http://www.wiki.xilinx.com/XAPP1079+Latest+Information
    quote - "Since the FSBL in EDK14.5 supports multiple ELF files, continue following the steps documented in the XAPP but during creation of the FSBL, select the template 'Zynq FSBL'. The 'Zynq FSBL for AMP' template is no longer required and has been removed from the design."
