ZedBoard Hardware Design Zedboard Linux Boot hangs at "mousedev: PS/2 mouse device common for all mice"
  • Subscribers 359 subscribers
  • Views 879 views
Hi All,
I have followed this guide
http://www.digilentinc.com/Data/Products/EMBEDDED-LINUX/ZedBoard_GSwEL_Guide.pdf
to boot Linux on the Zedboard.
I downloaded the Linux kernel and device tree source codes from
https://github.com/Digilent/linux-digilent.git
and after compilation, I obtained zImage, devicetree.dtb and I copied them to the SD card.
However, when I tried to boot Linux, it hangs at "mousedev: PS/2 mouse device common for all mice" and I really have no clues what the problems are.
Below is the message log:
____________________________________________________________
U-Boot 2012.04.01 (Nov 04 2014 06:15:49)
DRAM:  512 MiB
WARNING: Caches not enabled
MMC:   SDHCI: 0
Using default environment
In:    serial
Out:   serial
Err:   serial
Net:   zynq_gem
Hit any key to stop autoboot:  0
Copying Linux from SD to RAM...
Device: SDHCI
Manufacturer ID: 3
OEM: 5344
Tran Speed: 25000000
Rd Block Len: 512
SD version 2.0
High Capacity: Yes
Capacity: 7.4 GiB
Bus Width: 4-bit
reading zImage
2406200 bytes read
reading devicetree.dtb
9973 bytes read
reading ramdisk8M.image.gz
2500546 bytes read
## Starting application at 0x00008000 ...
Uncompressing Linux... done, booting the kernel.
[    0.000000] Booting Linux on physical CPU 0
[    0.000000] Linux version 3.6.0-digilent-13.01-00002-g06b3889 (casrm@casrm) (gcc version 4.8.1 (Sourcery CodeBench Lite 4
[    0.000000] CPU: ARMv7 Processor [413fc090] revision 0 (ARMv7), cr=18c5387d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] Machine: Xilinx Zynq Platform, model: Xilinx Zynq ZED
[    0.000000] Memory policy: ECC disabled, Data cache writealloc
[    0.000000] PERCPU: Embedded 7 pages/cpu @c140a000 s6976 r8192 d13504 u32768
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 130048
[    0.000000] Kernel command line: console=ttyPS0,115200 root=/dev/ram rw initrd=0x800000,8M earlyprintk
[    0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[    0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[    0.000000] Memory: 512MB = 512MB total
[    0.000000] Memory: 506676k/506676k available, 17612k reserved, 0K highmem
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
[    0.000000]     vmalloc : 0xe0800000 - 0xfd000000   ( 456 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xe0000000   ( 512 MB)
[    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
[    0.000000]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
[    0.000000]       .text : 0xc0008000 - 0xc04393bc   (4293 kB)
[    0.000000]       .init : 0xc043a000 - 0xc045fb40   ( 151 kB)
[    0.000000]       .data : 0xc0460000 - 0xc0498f60   ( 228 kB)
[    0.000000]        .bss : 0xc0498f84 - 0xc04af730   (  90 kB)
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000]  Dump stacks of tasks blocking RCU-preempt GP.
[    0.000000]  RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
[    0.000000] NR_IRQS:512
[    0.000000] Zynq clock init
[    0.000000] xlnx,ps7-ttc-1.00.a #0 at 0xe0800000, irq=43
[    0.000000] sched_clock: 32 bits at 100 Hz, resolution 10000000ns, wraps every 4294967286ms
[    0.000000] Console: colour dummy device 80x30
[    0.090000] Calibrating delay loop... 1332.01 BogoMIPS (lpj=6660096)
[    0.090000] pid_max: default: 32768 minimum: 301
[    0.090000] Mount-cache hash table entries: 512
[    0.090000] CPU: Testing write buffer coherency: ok
[    0.090000] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.090000] hw perfevents: enabled with ARMv7 Cortex-A9 PMU driver, 7 counters available
[    0.090000] Setting up static identity map for 0x300f30 - 0x300f64
[    0.090000] L310 cache controller enabled
[    0.090000] l2x0: 8 ways, CACHE_ID 0x410000c8, AUX_CTRL 0x72360000, Cache size: 524288 B
[    0.130000] Map SLCR registers
[    0.130000] CPU1: Booted secondary processor
[    0.220000] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.220000] Brought up 2 CPUs
[    0.220000] SMP: Total of 2 processors activated (2664.03 BogoMIPS).
[    0.220000] devtmpfs: initialized
[    0.220000] NET: Registered protocol family 16
[    0.220000] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.220000] xgpiops e000a000.ps7-gpio: gpio at 0xe000a000 mapped to 0xe084a000
[    0.230000] registering platform device 'pl330' id 0
[    0.230000] registering platform device 'arm-pmu' id 0
[    0.230000] registering platform device 'zynq-dvfs' id 0
[    0.230000] hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
[    0.230000] hw-breakpoint: maximum watchpoint size is 4 bytes.
[    0.250000] xslcr xslcr.0: at 0xF8000000 mapped to 0xF8000000
[    0.260000] bio: create slab <bio-0> at 0
[    0.270000] SCSI subsystem initialized
[    0.270000] usbcore: registered new interface driver usbfs
[    0.270000] usbcore: registered new interface driver hub
[    0.270000] usbcore: registered new device driver usb
[    0.270000] Advanced Linux Sound Architecture Driver Version 1.0.25.
[    0.270000] Switching to clocksource xttcpss_timer1
[    0.280000] NET: Registered protocol family 2
[    0.280000] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[    0.280000] TCP bind hash table entries: 16384 (order: 5, 131072 bytes)
[    0.280000] TCP: Hash tables configured (established 16384 bind 16384)
[    0.280000] TCP: reno registered
[    0.280000] UDP hash table entries: 256 (order: 1, 8192 bytes)
[    0.280000] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[    0.280000] NET: Registered protocol family 1
[    0.280000] Trying to unpack rootfs image as initramfs...
[    0.280000] rootfs image is not initramfs (no cpio magic); looks like an initrd
[    0.310000] Freeing initrd memory: 8192K
[    0.320000] pl330 dev 0 probe success
[    0.320000] msgmni has been set to 1005
[    0.320000] io scheduler noop registered
[    0.320000] io scheduler deadline registered
[    0.320000] io scheduler cfq registered (default)
[    0.320000] e0001000.serial: ttyPS0 at MMIO 0xe0001000 (irq = 82) is a xuartps
[    0.780000] console [ttyPS0] enabled
[    0.780000] xdevcfg f8007000.ps7-dev-cfg: ioremap f8007000 to e0850000 with size 1000
[    0.790000] [drm] Initialized drm 1.1.0 20060810
[    0.800000] brd: module loaded
[    0.810000] loop: module loaded
[    0.820000] xqspips e000d000.ps7-qspi: master is unqueued, this is deprecated
[    0.820000] xqspips e000d000.ps7-qspi: at 0xE000D000 mapped to 0xE0852000, irq=51
[    0.830000] libphy: XEMACPS mii bus: probed
[    0.840000] xemacps e000b000.ps7-ethernet: pdev->id -1, baseaddr 0xe000b000, irq 54
[    0.850000] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.850000] usb_hcd_xusbps_probe: No OTG assigned!
[    0.860000] usb_hcd_xusbps_probe: OTG now assigned!
[    0.860000] xusbps-ehci xusbps-ehci.0: Xilinx PS USB EHCI Host Controller
[    0.870000] xusbps-ehci xusbps-ehci.0: new USB bus registered, assigned bus number 1
[    0.910000] xusbps-ehci xusbps-ehci.0: irq 53, io mem 0x00000000
[    0.930000] xusbps-ehci xusbps-ehci.0: USB 2.0 started, EHCI 1.00
[    0.930000] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    0.940000] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.950000] usb usb1: Product: Xilinx PS USB EHCI Host Controller
[    0.950000] usb usb1: Manufacturer: Linux 3.6.0-digilent-13.01-00002-g06b3889 ehci_hcd
[    0.960000] usb usb1: SerialNumber: xusbps-ehci.0
[    0.960000] hub 1-0:1.0: USB hub found
[    0.970000] hub 1-0:1.0: 1 port detected
[    0.970000] Initializing USB Mass Storage driver...
[    0.980000] usbcore: registered new interface driver usb-storage
[    0.980000] USB Mass Storage support registered.
[    0.990000] mousedev: PS/2 mouse device common for all mice
I would be very grateful if anyone could help me out on this...I have been struggling on this for a few weeks...
    Hi
    In my experience boot problems are generally caused by a problem with the device tree.  As a starting point, you probably won't have the device driver for the OLED screen in your kernel, so you should remove this from the device tree.  If you need help with modifying your device tree I'd suggest reading the tutorial below:
    http://xillybus.com/tutorials/device-tree-zynq-1
    Matthew
    0 Former Member over 11 years ago in reply to Former Member
    Thank you very much for your quick reply,
    I have removed the OLED screen in the device tree and the problem still exists...Yet when I tried to replace my compiled zimage to the zimage that I got online at
    http://zedboard.org/sites/default/files/design/zedboard_refdoc_Vivado_2014-2.zip
    I was able to boot...Therefore I was wondering if it is the problem of the kernel source code or it is because of the problem that the device tree and the zimage doesn't play well with each other.
    I wish I could use the zimage downloaded directly but I could not because I need other drivers as well.
    I sincerely hope that you could give me some insights on solving this problem....I am really fustrated :(
    Below is the message log after replacing the zimage.
    In:    serial
    Out:   serial
    Err:   serial
    Net:   zynq_gem
    zed-boot> run sdboot
      sdboot sdboot_linaro
    zed-boot> run sdboot_linaro
    Device: SDHCI
    Manufacturer ID: 12
    OEM: 3456
    Rd Block Len: 512
    SD version 2.0
    High Capacity: Yes
    Capacity: 3.7 GiB
    Bus Width: 4-bit
    reading zImage
    2362936 bytes read
    reading devicetree_linaro.dtb
    9652 bytes read
    [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache 6
    [    0.000000] PERCPU: Embedded 7 pages/cpu @c08a3000 s6976 r8192 d13504 u32768
    [    0.000000] Kernel command line: console=ttyPS0,115200 root=/dev/mmcblk0p2 rw earlyprintk rootfstype=ext4 rootwait devtm1
    [    0.000000] Memory: 514948k/514948k available, 9340k reserved, 0K highmem
    [    0.000000]       .text : 0xc0008000 - 0xc0425cac   (4216 kB)
    [    0.000000]       .init : 0xc0426000 - 0xc044bb40   ( 151 kB)
    [    0.000000]       .data : 0xc044c000 - 0xc04849a0   ( 227 kB)
    [    0.000000]        .bss : 0xc04849c4 - 0xc049b130   (  90 kB)
    [    0.090000] Setting up static identity map for 0x2f1490 - 0x2f14c4
    [    0.280000] pl330 dev 0 probe success
    [    0.290000] msgmni has been set to 1005
    [    0.290000] io scheduler noop registered
    [    0.290000] io scheduler deadline registered
    [    0.290000] io scheduler cfq registered (default)
    [    0.290000] e0001000.serial: ttyPS0 at MMIO 0xe0001000 (irq = 82) is a xuartps
    [    0.730000] console [ttyPS0] enabled
    [    0.740000] xdevcfg f8007000.ps7-dev-cfg: ioremap f8007000 to e0850000 with size 1000
    [    0.740000] [drm] Initialized drm 1.1.0 20060810
    [    0.760000] brd: module loaded
    [    0.770000] loop: module loaded
    [    0.770000] xqspips e000d000.ps7-qspi: master is unqueued, this is deprecated
    [    0.780000] xqspips e000d000.ps7-qspi: at 0xE000D000 mapped to 0xE0852000, irq=51
    [    0.790000] libphy: XEMACPS mii bus: probed
    [    0.790000] xemacps e000b000.ps7-ethernet: pdev->id -1, baseaddr 0xe000b000, irq 54
    [    0.800000] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
    [    0.810000] usb_hcd_xusbps_probe: No OTG assigned!
    [    0.810000] usb_hcd_xusbps_probe: OTG now assigned!
    [    0.820000] xusbps-ehci xusbps-ehci.0: Xilinx PS USB EHCI Host Controller
    [    0.830000] xusbps-ehci xusbps-ehci.0: new USB bus registered, assigned bus number 1
    [    0.860000] xusbps-ehci xusbps-ehci.0: irq 53, io mem 0x00000000
    [    0.880000] xusbps-ehci xusbps-ehci.0: USB 2.0 started, EHCI 1.00
    [    0.880000] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
    [    0.890000] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [    0.900000] usb usb1: Product: Xilinx PS USB EHCI Host Controller
    [    0.900000] usb usb1: Manufacturer: Linux 3.6.0-digilent-13.01-00002-g06b3889 ehci_hcd
    [    0.910000] usb usb1: SerialNumber: xusbps-ehci.0
    [    0.910000] hub 1-0:1.0: USB hub found
    [    0.920000] hub 1-0:1.0: 1 port detected
    [    0.920000] Initializing USB Mass Storage driver...
    [    0.930000] usbcore: registered new interface driver usb-storage
    [    0.930000] USB Mass Storage support registered.
    [    0.940000] mousedev: PS/2 mouse device common for all mice
    Sorry I copied the wrong msg log......This is the right one
    U-Boot 2012.04.01 (Nov 04 2014 - 06:15:49)
    DRAM:  512 MiB
    MMC:   SDHCI: 0
    In:    serial
    Out:   serial
    Err:   serial
    Net:   zynq_gem
    Device: SDHCI
    Manufacturer ID: 3
    OEM: 5344
    Rd Block Len: 512
    SD version 2.0
    High Capacity: Yes
    Capacity: 7.4 GiB
    Bus Width: 4-bit
    reading zImage
    2402648 bytes read
    5749 bytes read
    2500546 bytes read
    Linux version 3.3.0-14.2-build1-01464-ged63a4d (training@ubuntu) (gcc version 4.6.1 (Sourcery CodeBench Lite 2011.09-50) ) 2
    bootconsole [earlycon0] enabled
    PERCPU: Embedded 7 pages/cpu @c1489000 s5696 r8192 d14784 u32768
    Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 125824
    Memory: 240MB 256MB = 496MB total
    Memory: 490008k/490008k available, 34280k reserved, 0K highmem
        vmalloc : 0xe0800000 - 0xff000000   ( 488 MB)
          .text : 0xc0008000 - 0xc0409c4c   (4104 kB)
          .init : 0xc040a000 - 0xc042e640   ( 146 kB)
          .data : 0xc0430000 - 0xc045dba0   ( 183 kB)
           .bss : 0xc045dbc4 - 0xc0477e1c   ( 105 kB)
            Verbose stalled-CPUs detection is disabled.
    NR_IRQS:128
    Calibrating delay loop... 1594.16 BogoMIPS (lpj=7970816)
    smp_twd: clock not found: -2
    Calibrating local timer... 399.29MHz.
    Setting up static identity map for 0x2f11d8 - 0x2f120c
    Brought up 2 CPUs
    SMP: Total of 2 processors activated (3188.32 BogoMIPS).
    xslcr xslcr.0: at 0xF8000000 mapped to 0xE0808000
    gpiochip_add: registered GPIOs 0 to 245 on device: xgpiops
    xgpiops e000a000.gpio: gpio at 0xe000a000 mapped to 0xe080a000
    IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
    TCP bind hash table entries: 16384 (order: 5, 196608 bytes)
    TCP reno registered
    RPC: Registered named UNIX socket transport module.
    RPC: Registered udp transport module.
    RPC: Registered tcp transport module.
    RPC: Registered tcp NFSv4.1 backchannel transport module.
    xscugtimer xscugtimer.0: ioremap fe00c200 to e080c200 with size 400
    JFFS2 version 2.2. (NAND) (SUMMARY)  u00A9 2001-2006 Red Hat, Inc.
    msgmni has been set to 973
    loop: module loaded
    xqspips e000d000.qspi: at 0xE000D000 mapped to 0xE0862000, irq=51
    GEM: BASEADDRESS hw: e000b000 virt: e0864000
    eth0, pdev->id -1, baseaddr 0xe000b000, irq 54
    Xilinx PS USB Device Controller driver (Apr 01, 2011)
    i2c /dev entries driver
    Linux video capture interface: v2.00
    gspca_main: v2.14.0 registered
    uvcvideo: Unable to create debugfs directory
    usbcore: registered new interface driver uvcvideo
    USB Video Class driver (1.1.1)
    WDT OF probe
    xwdtps f8005000.swdt: Xilinx Watchdog Timer at 0xe0868000 with timeout 10 seconds
    sdhci: Secure Digital Host Controller Interface driver
    sdhci: Copyright(c) Pierre Ossman
    sdhci-pltfm: SDHCI platform and OF driver helper
    mmc0: Invalid maximum block size, assuming 512 bytes
    mmc0: SDHCI controller on e0100000.sdhci [e0100000.sdhci] using ADMA
    usbcore: registered new interface driver usbhid
    usbhid: USB HID core driver
    TCP cubic registered
    NET: Registered protocol family 17
    VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
    Registering SWP/SWPB emulation handler
    drivers/rtc/hctosys.c: unable to open rtc device (rtc0)
    RAMDISK: gzip image found at block 0
    mmc0: new high speed SDHC card at address e624
    mmcblk0: mmc0:e624 SU08G 7.40 GiB
    mmcblk0: p1 p2
    VFS: Mounted root (ext2 filesystem) on device 1:0.
    devtmpfs: mounted
    Freeing init memory: 144K
    Starting rcS...
    ++ Mounting filesystem
    ++ Setting up mdev
    ++ Starting telnet daemon
    ++ Starting http daemon
    ++ Starting ftp daemon
    ++ Starting dropbear (ssh) daemon
    rcS Complete
    zynq>
    Hi
    I have previously used the Digilent kernel without any problems, so I doubt it's a problem with the source.  I'd suggest removing everything in your device tree except the essential components and add things back until it stops working again.
    It looks like your first log fails when the second one reaches "i2c /dev entries driver".  Possibly a good idea to search the device tree for an i2c component and remove that.
    For reference I have a basic one which should work:
    /dts-v1/;
    tmodel = "Xilinx Zynq ZED";
    tcompatible = "xlnx,zynq-zed";
    t#address-cells = <0x1>;
    t#size-cells = <0x1>;
    tinterrupt-parent = <0x1>;
    tmemory@0 {
    ttdevice_type = "memory";
    ttreg = <0x0 0x20000000>;
    t};
    tchosen {
    ttbootargs = "console=ttyPS0,115200 root=/dev/ram rw initrd=0x800000,8M earlyprintk rootfstype=ext4 rootwait devtmpfs.mount=0";
    ttlinux,stdout-path = "/axi@0/uart@E0001000";
    t};
    tcpus {
    tt#address-cells = <0x1>;
    tt#cpus = <0x2>;
    tt#size-cells = <0x0>;
    ttcpu@0 {
    tttclock-frequency = <0x27bc86bf>;
    tttcompatible = "xlnx,ps7-cortexa9-1.00.a";
    tttd-cache-line-size = <0x20>;
    tttd-cache-size = <0x8000>;
    tttdevice_type = "cpu";
    ttti-cache-line-size = <0x20>;
    ttti-cache-size = <0x8000>;
    tttmodel = "ps7_cortexa9,1.00.a";
    tttreg = <0x0>;
    ttttimebase-frequency = <0x13de435f>;
    tttxlnx,cpu-1x-clk-freq-hz = <0x69f6bcb>;
    tttxlnx,cpu-clk-freq-hz = <0x27bc86bf>;
    tt};
    ttcpu@1 {
    tttreg = <0x1>;
    tt};
    t};
    taxi@0 {
    tt#size-cells = <0x1>;
    ttcompatible = "xlnx,ps7-axi-interconnect-1.00.a", "simple-bus";
    ttranges;
    ttintc@f8f01000 {
    tttinterrupt-controller;
    tttcompatible = "arm,cortex-a9-gic";
    ttt#interrupt-cells = <0x3>;
    tttreg = <0xf8f01000 0x1000 0xf8f00100 0x100>;
    tttlinux,phandle = <0x1>;
    tttphandle = <0x1>;
    tt};
    ttpl310@f8f02000 {
    tttcompatible = "arm,pl310-cache";
    tttcache-unified;
    tttcache-level = <0x2>;
    tttreg = <0xf8f02000 0x1000>;
    tttarm,data-latency = <0x3 0x2 0x2>;
    tttarm,tag-latency = <0x2 0x2 0x2>;
    tttinterrupts = <0x0 0x22 0x4>;
    tt};
    ttuart@e0001000 {
    tttcompatible = "xlnx,ps7-uart-1.00.a";
    tttreg = <0xe0001000 0x1000>;
    tttinterrupts = <0x0 0x32 0x0>;
    tttinterrupt-parent = <0x1>;
    tttclock = <0x2faf080>;
    tt};
    tttimer@0xf8001000 {
    tttcompatible = "xlnx,ps7-ttc-1.00.a";
    tttreg = <0xf8001000 0x1000>;
    tttinterrupts = <0x0 0xa 0x0 0x0 0xb 0x0 0x0 0xc 0x0>;
    tttclock-frequency-timer0 = <0x7ed6b40>;
    tttclock-frequency-timer1 = <0x7ed6b40>;
    tttclock-frequency-timer2 = <0x7ed6b40>;
    tt};
    ttswdt@f8005000 {
    tttdevice_type = "watchdog";
    tttcompatible = "xlnx,ps7-wdt-1.00.a";
    tttreg = <0xf8005000 0x100>;
    tttclock-frequency = <0x69f6bc7>;
    tt};
    tteth@e000b000 {
    tttcompatible = "xlnx,ps7-ethernet-1.00.a";
    tttreg = <0xe000b000 0x1000>;
    tttinterrupts = <0x0 0x16 0x0>;
    tttphy-handle = <0x2>;
    ttt#address-cells = <0x1>;
    ttt#size-cells = <0x0>;
    tttxlnx,ptp-enet-clock = <0x69f6bc7>;
    tttxlnx,slcr-div0-1000Mbps = <0x8>;
    tttxlnx,slcr-div0-100Mbps = <0x8>;
    tttxlnx,slcr-div0-10Mbps = <0x8>;
    tttxlnx,slcr-div1-1000Mbps = <0x1>;
    tttxlnx,slcr-div1-100Mbps = <0x5>;
    tttxlnx,slcr-div1-10Mbps = <0x32>;
    tttmdio {
    tttt#address-cells = <0x1>;
    tttt#size-cells = <0x0>;
    ttttphy@0 {
    tttttcompatible = "marvell,88e1510";
    tttttdevice_type = "ethernet-phy";
    tttttreg = <0x0>;
    tttttmarvell,reg-init = <0x3 0x10 0xff00 0x1e 0x3 0x11 0xfff0 0xa>;
    tttttlinux,phandle = <0x2>;
    tttttphandle = <0x2>;
    tttt};
    ttt};
    tt};
    ttsdhci@e0100000 {
    tttcompatible = "xlnx,ps7-sdhci-1.00.a";
    tttreg = <0xe0100000 0x1000>;
    tttinterrupts = <0x0 0x18 0x0>;
    tttxlnx,has-cd = <0x1>;
    tttclock-frequency = <0x1fc9f08>;
    tt};
    ttusb@e0002000 {
    tttcompatible = "xlnx,ps7-usb-1.00.a";
    tttreg = <0xe0002000 0x1000>;
    tttinterrupts = <0x0 0x15 0x0>;
    tttdr_mode = "host";
    tttphy_type = "ulpi";
    tt};
    ttgpio@e000a000 {
    tttcompatible = "xlnx,ps7-gpio-1.00.a";
    ttt#gpio-cells = <0x2>;
    tttreg = <0xe000a000 0x1000>;
    tttinterrupts = <0x0 0x14 0x0>;
    tttgpio-controller;
    tttlinux,phandle = <0x8>;
    tttphandle = <0x8>;
    tt};
    ttqspi@e000d000 {
    tttcompatible = "xlnx,ps7-qspi-1.00.a";
    tttreg = <0xe000d000 0x1000>;
    tttinterrupts = <0x0 0x13 0x0>;
    tttspeed-hz = <0xbebc200>;
    tttbus-num = <0x1>;
    tttnum-chip-select = <0x1>;
    tttis-dual = <0x0>;
    tt};
    ttdevcfg@f8007000 {
    tttcompatible = "xlnx,ps7-dev-cfg-1.00.a";
    tttreg = <0xf8007000 0x1000>;
    tttinterrupts = <0x0 0x8 0x0>;
    tt};
    t};
    Matthew
