I'm trying to connect the axi_vdma_0 M_AXI_MM2S and M_AXI_S2MM to memory on the Zedboard. Its not clear if I should use a MIG or just use the auto connection. I understand that the Zedboard has the DDR memory attached to the PL via an AMBA switch. If this is the case what is the system for connecting to this AMBA switch.
I'm referring to http://www.xilinx.com/support/documentation/application_notes/xapp794-1080p60-camera.pdf
In this document it suggest that the memory is connected to the PS. Please can you clarify how this is done.
