ZedBoard Hardware Design Power is not coming to Board
  • Subscribers 359 subscribers
  • Views 646 views
satishkumar
satishkumar over 10 years ago
Hi all,
I am using/working with ZED board from last 1 year,
I got issue yesterday, Power is not coming to board, I checked connection between serial port to Host PC & Board to Power Connection, both are looking fine.
lsusb is not showing any data.
Please help to resolve this issue asap.
Thanks & Regards
Satish.G
  • bhfletcher
    0 bhfletcher over 10 years ago
    Are any of the LEDs turning on? Have you checked any of the on-board supplies to see if the correct voltages are seen as per the ZedBoard UG?
    Are you able to configure the device with a bitstream? Have you tried multiple methods -- JTAG, QSPI, SD Card?
    Bryan
  • satishkumar
    0 satishkumar over 10 years ago in reply to bhfletcher
    No LEDs are are turning on.
    I am using same setup where earlier it blinks green LED with Power on and Yellow light blinks for sending any char from Keyboard(Once it is booted & through Minicom).
    I had bitstream file which is pre built FSBL copied to SD card, custom uImage, Device tree (Prebuilt) & Ramdisk Image (Prebuilt).
    So I had changed only uImage from working to not-working, so I copied different uImage and tested but still there is no Green LED Blink.
    I checked Power cable provided with ZED board, it is internally having one led glowing (green) when switch is on, and other end connected to board.
    Should I change the Power cable or is that any other issue?
    Thanks & Regards
    Satish.G
  • satishkumar
    0 satishkumar over 10 years ago in reply to satishkumar
    Hi all,
    Pls reply to my query, I am just waiting for the root cause of Board issue.
    Thanks & Regards
    Satish.G
  • bhfletcher
    0 bhfletcher over 10 years ago in reply to satishkumar
    It would appear that either your power cable or board is no longer working. You will likely need to get a new power cable or board. You could contact your local Avnet FAE to assist you in debugging. What you are seeing is not a common issue that anyone else has reported.
    Bryan
  • satishkumar
    ok thank you,
    I believe this should be problem with Power Cable, not with the Board, as it effects me a lot.
    Thanks & Regards
    Satish.G
  • bhfletcher
    You may be able to purchase a replacement through Digilent (www.digilentinc.com).
    The Part Number that I have on my ZedBoard supply is Powertron Electronics Corp. Model # PA1060-120IB500
    Bryan
