ZedBoard Hardware Design Running RTOS on CPU0 and Linux on CPU1
  • Subscribers 359 subscribers
  • Views 448 views
I have implemeted xapp 1079 (Standalone apps on both cpu) and xapp 1078 which runs Linux on CPU0 and RTOS on CPU1.
Now I am trying to run RTOS on CPU0 and Linux on CPU1.
I would like to know whether RTOS can be used as master running on CPU0 and What are the important factors that i need to consider.
Thanks and Regards,
Darshan
  • drozwood90
    0 drozwood90 over 10 years ago
    Darshan,
    It seems you are working with specifics of XAPP1079.  You might want to try posting to Xilinx's forum on this.
    https://forums.xilinx.com/t5/Zynq-All-Programmable-SoC/bd-p/zaps
    I found a few other references to XAPP1079 at that link.
    --Dan
    0 Former Member over 10 years ago in reply to drozwood90
    Hi Dan,
    I have posted this question in Xilinx forun but didn't got any response :(
    https://forums.xilinx.com/t5/Zynq-All-Programmable-SoC/Running-RTOS-on-CPU0-and-Linux-on-CPU1/m-p/679930#M11720
    Darshan,
    Try a google search of OpenAMP + Xilinx, there are lots of references that can provide information to move forward.  What you want is indeed possible under the full OpenAMP framework, but currently I do not believe there is a Xilinx implementation that puts the RTOS as the master and Linux as the slave.  That doesn't mean it isn't possible, as the full OpenAMP framework does not preclude this.   But I would expect there will be some extra engineering required to get this to work, as to my knowledge nobody has a working example for Zynq.
    If anyone has, please chime in.
    Ron
