ZedBoard Hardware Design AMP Zedboard
  • Subscribers 359 subscribers
  • Views 611 views
AMP Zedboard
Hi ,
I want to run an AMP Configuration on my Zedboard : Petalinux cpu 0 / RTEMS cpu 1. Rtems is an RTOS , rtems apps are compiled outside of the SDK , so I have the already compiled rtems-app.elf wich I want to run on the cpu 1 .
I looked to OpenAMP framework but it seems that is not support such a configuration : because I think the framework compile .c files with the library and then generate .elf and I can't do such a thing my .elf is already compiled so I don't know how to use the openAMP solution..
Also,Is there a possiblity to configure petalinux to launch this .elf on cpu1 ? I managed to get it on rootfs configuration and I built petalinux with that app ( I specified also maxcpu=1) but doesn't work.
So , please help me to get this working. If anybody tried doing this before please suggest me a workflow or ideas.
Best
Thank you
    Have you looked at XAPP1078?
    http://www.wiki.xilinx.com/XAPP1078+Latest+Information#Simple%20AMP:%20Linux%20on%20CPU0%20and%20Bare-metal%20on%20CPU1%20XAPP1078%20Updates-Running%20XAPP1078%20on%20the%20ZedBoard
    While it does not use the newer Open AMP workflow I don't know of any Open AMP examples for Zynq right now.
    Here is a link to an earlier forum thread on xapp1078 and AMP designs.
    http://zedboard.org/content/xilinx-linuxfreertos-amp
    Do make sure to follow the newer updates listed at the bottom of the xapp1078 wiki page.
    -Gary
    0 Former Member over 10 years ago in reply to Former Member
    Yes, these notes didn't work for me. I didn't use the design for vivado 2014.4. The design proposed uses chipscope and I don't have the licence. Does anybody have a have a hardware design working with xapp 1078 for vivado 2014.4 without chipscope ?
    Starting with Vivado 2015.4 Vivado Debug (ChipScope equivalent) is now included with the free webpack license. If you generated your license prior to 2015.4 initially you will need to regenerate the license to take advantage of this. Starting with Vivado 2016.1 a license is no longer required.
    http://zedboard.org/content/vivado-debug-tools-webpack-vivado-design-edition-smaller-devices
    -Gary
    I have to work on 2014.4 version, there is no an equivalent design without chipscope IP that works for xapp1078 ?
    I don't know of another Xilinx app note for AMP with Linux and Bare Metal. You could post the question on the Xilinx Community Forums.
    But, if you are using the pre-built hardware from XAPP1078, I don't think you need the Analyzer license to use the ILA cores, just to generate them.
    I found this blog with a Linux/Bare Metal AMP but I do not know how well it works:
    http://henryomd.blogspot.com/2015/02/zynq-amp-linux-on-cpu0-and-bare-metal.html
    -Gary
