ZedBoard Hardware Design PS-PL communication
  • Subscribers 361 subscribers
  • Views 1316 views
PS-PL communication
surajitmal
surajitmal over 9 years ago
I'm very new in zynq platform. We are trying to communicate between PL-PS or vice versa. We have 188 byte generic message which is coming irregular interval of time from TCP/IP. We need to send those Generic Message from PS to PL device. PL device convert those generic message as per our requirement. Then we need to send those output data to again PS from PL.
Could anyone help me with some example about AXI-Stream so that we can proceed further.
  • jafoste4
    0 jafoste4 over 9 years ago
    Hello Surajitmal,
    What board are you using?
    Also try taking a look at this document https://www.xilinx.com/support/documentation/ip_documentation/axi_ethernet/v3_01_a/ds759_axi_ethernet.pdf
    Josh
  • surajitmal
    0 surajitmal over 9 years ago in reply to jafoste4
    Thanks for your reply.
    I'm using Zynq 7000 AP SoC. The problem we are facing about the communication between PL-PS. It's quite easy to design using AXI_lite but its difficult to design using AXI- Stream & very less documentation are there throughout the xilinx-forum.
  • jafoste4
    Hello Sirajitmal,
    Are you using one of the development boards we offer? Such as the MicroZed, PicoZed, Zedboard, Ect.?
    --Josh
  • surajitmal
    Hello JFoster,
    Yes, I'm using ZedBoard. Could you please provide me few design related documents for PS-PL communication.
  • jafoste4
    Hi Surajitmal,
    You may want to try this example code located within SDK
    C:\Xilinx\SDK\2017.1\data\embeddedsw\XilinxProcessorIPLib\drivers\llfifo_v5_1\src\xstreamer.c
    I also found this bit of information in regards to Transfering dats from Zynq PL to PS using AXI Stream that may be helpful.
    http://www.googoolia.com/wp/2014/07/24/software-development-for-the-arm-...
    --Josh
