ZedBoard Hardware Design XADC and led ?
  • Subscribers 360 subscribers
  • Views 460 views
XADC and led ?
100gma
100gma over 11 years ago
hello
i will implement XADC on Zedboard, in order to detect a specific value of temperature
1/ when we add XADC, it will be placed into PL ?
2/ can we connect the XADC to leds, in other way, when we detect a trigger ( value fixed during the setup of XADC), maybe to open some leds, as an alert ?
3/ when we export the project to SDK, it's possible to program it, with c language ?
thank you
    1. XADC implemented in a silicon. You cannot 'move' it. Why it matter for you?
    2. Yes.
    3. Yes.
  • 100gma
    0 100gma over 11 years ago
    hi
    thank you for response
    1- i mean, the xadc is located into PL, after load the bit file ?
    2- when i added the xadc wizard to my design, i run the connection automation, the output alarm, doesn't connect to any bloc ( for output show )
    i can't found a documentation on xilinx website, talked about how read on led or Oled the temperature ( getting from xadc ( temperature sensor) ?
    any suggestion
    thank you
