ZedBoard Hardware Design Simulating Zynq Processing System
  • Replies 7 replies
  • Subscribers 359 subscribers
  • Views 1560 views
I'm quite new to Xilinx tools and everything around them, so this might be a stupid question ;)
I'd like to simulate my ZedBoard/Zynq Design with custom Peripherals, but somehow, Vivado isn't generating Simulation sources/files for the processing system (the actual Dual ARM Cortex-A9-whatsoever IP core).
To verify the behavior of my Component (CPU(IP) <-> AXI Bus Bridge(my code) <-> Slave Peripheral(my code)), I wrote a Testbench instantiating the arm wrapper (the one generated by Vivado when clicking 'Create VHDL Wrapper...') and a (System-)Verilog DDR3 model from Micron.
When running Behavioral Simulation in ModelSim (invoking through Vivado), Modelsim keeps warning me that the component instance "processing_system7_1 : arm_processing_system7_1_0" is not bound. (My Block diagram is called arm.bd; that's where the 'arm_' prefix comes from).
How do i get Vivado to export the IP sources for Simulation?
How do you guys simulate your Zynq-Design?
Thanks in advance and best regards,
Stefan
    It's been a week and I still couldn't figure out how to simulate the PS.
    Has nobody ever tried to do that?
  • bhfletcher
    0 bhfletcher over 12 years ago
    Did you install the patch?
    http://www.xilinx.com/support/answers/56492.htm
    Bryan
    Thanks for the response!
    I installed the patch as mentioned on the support page,
    but I'm getting the exact same result.
    I tried creating the project from scratch (again), component is still "not bound".
    Do I have to switch to Verilog to make this work?
    By the way, Vivado has no problem synthesizing the entire project. Also, the sub-block called "processing_system7_1(.xci)" of my .bd is illustrated properly and doesn't behave as the one mentioned in the support page you posted (orange box in Hierarchy View).
    Stefan
  • bhfletcher
    I'm sorry, but I'm not sure what the problem is. I suggest you open a case with Xilinx Support and/or post to the Xilinx Forum -- www.xilinx.com/support
    Bryan
    Bryan, did you ever simulate the PS?
    Maybe I'm doing something wrong in my project...
    If you got it running, could you send me an example project?
    Stefan
    I found this:
    https://secure.xilinx.com/webreg/ clickthrough.do?filename=axi_bfm_ug_examples.tar.gz
    I haven't verified the functionality yet, but this seems to be a good alternative to simulating the entire PS.
    Stefan
    Hi ,
    has any one tried simulating PS side of the ZYNQ comprising DDR3SDRAM . If yes please share me the procedure.
    regards
    chandra
