ZedBoard Hardware Design DDR3 Memory
  • Subscribers 359 subscribers
  • Views 489 views
DDR3 Memory
gge7
gge7 over 9 years ago
<p>Hello Again.</p>
<p> </p>
<p>I wanted to ask another question about the Zedboard.  This one is particular to the DDR3 Memory spec&#39;d out for the Zedboard.  We are currently using the Zedboard and want to make a custom version of it.  Looking at the DDR3 spec&#39;d out it is the Micron, MT41K128M16JT-125:K which is hard to find in stock with anyone.  Is there a qualified 2nd source for the memory that is easier to obtain and would not change any of the parameters in firmware/software side?</p>
<p> </p>
<p>Thanks</p>
<p>Gary</p>
  • bhfletcher
    0 bhfletcher over 9 years ago
    Gary,
    Here are a few thoughts:
    •   I do not believe that there is a qualified 2nd source for the MT41K128M16JT-125:K, although to be sure, you would have to contact Digilent as they are the manufacturer of that board.
    •   From the Micron perspective, other temperature grades, speed grades, or going to the 256M depth would all be functionally compatible with MT41K128M16JT-125:K.
    •   Avnet Americas does have 3 similar products in stock, although minimum quantities are required. It might be worth checking with your local Avnet office to see if there is a way around those minimums.
        https://products.avnet.com/shop/SearchDisplay?searchTerm=MT41K128M16JT&storeId=715839035&catalogId=10001&langId=-1&sType=SimpleSearch&resultCatEntryType=2&showResultsPage=true&searchSource=Q&searchType=100&pageView=&beginIndex=0&pageSize=3&avnSearchType=all#facet=inStock%3A%22true%22&
    •   Although different boards, MicroZed and PicoZed use a very similar Micron 4G DDR3. On those boards, Avnet did qualify both Kingston and ISSI. See the following PCN: http://microzed.org/sites/default/files/documentations/Product%20Change%20Notification%20PCN16002.pdf
    •   From ease of use, ease of supply, ease of design, and faster time to market, I enourage you to consider designing a SOM Carrier card for one of the Zynq SOMs, like MicroZed or PicoZed, rather than doing a full chip-down design of your own. Then you don't have to worry about which specific DDR3's are compatible. You don't have to deal with high-speed layout of the DDR3/Zynq interface.
    •   Whether you move ahead with a carrier design or design based on ZedBoard, if you are willing to work with your Avnet FAE, they can get you the schematic/layout source files for either the ZedBoard or any of our SOM carriers. Contact your local Avnet FAE and request this.
    Bryan
