ZedBoard Hardware Design Zedboard vs Zybo
  • Subscribers 360 subscribers
  • Views 1659 views
Zedboard vs Zybo
I am new to Xilinx's Zynq, and I don't have years experience in FPGA. Although this is a Zedboard forum, I would like to know what I cannot do if I purchase a Zybo board instead of a Zedboard.
    main difference is there is no fmc connector on the zybo,
    except that they are pretty much the same board (same codecs, vga..)
  • zedhed
    0 zedhed over 11 years ago
    Hi FrankWL,
    In addition to the FMC connector difference, Zybo utilizes TMDS signaling to handle HDMI native through the Zynq I/Os. This has the benefit of supporting either HDMI input or output mode. However, the I/O signaling at that voltage level supports up to 720P resolutions. If you need to output 1080P resolution, the Analog Devices ADV7511 on the ZedBoard is recommended.
    -Kevin
