ZedBoard Hardware Design [NgdBuild 604] error with Zynq
  • Subscribers 359 subscribers
  • Views 317 views
100mokhtar
100mokhtar over 13 years ago
Hi all,
I created a register with AXI4-Lite slave. So I edited  the register file and I added the following treatment :
________________________________________
-- DO NOT EDIT BELOW THIS LINE --------------------
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_arith.all;
use ieee.std_logic_unsigned.all;
USE work.intra_16x16_pkg.ALL;
library proc_common_v3_00_a;
use proc_common_v3_00_a.proc_common_pkg.all;
-- DO NOT EDIT ABOVE THIS LINE --------------------
--USER libraries added here
-- Entity section
-- Definition of Generics:
--   C_NUM_REG                    -- Number of software accessible registers
--   C_SLV_DWIDTH                 -- Slave interface data bus width
-- Definition of Ports:
--   Bus2IP_Clk                   -- Bus to IP clock
--   Bus2IP_Resetn                -- Bus to IP reset
--   Bus2IP_Data                  -- Bus to IP data bus
--   Bus2IP_BE                    -- Bus to IP byte enables
--   Bus2IP_RdCE                  -- Bus to IP read chip enable
--   Bus2IP_WrCE                  -- Bus to IP write chip enable
--   IP2Bus_Data                  -- IP to Bus data bus
--   IP2Bus_RdAck                 -- IP to Bus read transfer acknowledgement
--   IP2Bus_WrAck                 -- IP to Bus write transfer acknowledgement
--   IP2Bus_Error                 -- IP to Bus error response
entity user_logic is
  generic
    -- ADD USER GENERICS BELOW THIS LINE ---------------
    --USER generics added here
    -- ADD USER GENERICS ABOVE THIS LINE ---------------
    -- DO NOT EDIT BELOW THIS LINE ---------------------
    -- Bus protocol parameters, do not add to or delete
    C_NUM_REG                      : integer              := 16;
    C_SLV_DWIDTH                   : integer              := 32
    -- DO NOT EDIT ABOVE THIS LINE ---------------------
  port
    -- ADD USER PORTS BELOW THIS LINE ------------------
    --USER ports added here
    -- ADD USER PORTS ABOVE THIS LINE ------------------
    -- Bus protocol ports, do not add to or delete
    Bus2IP_Clk                     : in  std_logic;
    Bus2IP_Resetn                  : in  std_logic;
    Bus2IP_Data                    : in  std_logic_vector(C_SLV_DWIDTH-1 downto 0);
    Bus2IP_BE                      : in  std_logic_vector(C_SLV_DWIDTH/8-1 downto 0);
    Bus2IP_RdCE                    : in  std_logic_vector(C_NUM_REG-1 downto 0);
    Bus2IP_WrCE                    : in  std_logic_vector(C_NUM_REG-1 downto 0);
    IP2Bus_Data                    : out std_logic_vector(C_SLV_DWIDTH-1 downto 0);
    IP2Bus_RdAck                   : out std_logic;
    IP2Bus_WrAck                   : out std_logic;
    IP2Bus_Error                   : out std_logic
  attribute MAX_FANOUT : string;
  attribute SIGIS : string;
  attribute SIGIS of Bus2IP_Clk    : signal is "CLK";
  attribute SIGIS of Bus2IP_Resetn : signal is "RST";
end entity user_logic;
-- Architecture section
architecture IMP of user_logic is
component ICT_TOP_LEVEL
   PORT
  (     CLK :IN STD_LOGIC;
        reset : IN STD_LOGIC;
        START : IN STD_LOGIC;
        residuel_in_0 : IN STD_LOGIC_VECTOR (31 DOWNTO 0) ;
        residuel_in_1 : IN STD_LOGIC_VECTOR (31 DOWNTO 0) ;
        residuel_in_2 : IN STD_LOGIC_VECTOR (31 DOWNTO 0) ;
        residuel_in_3 : IN STD_LOGIC_VECTOR (31 DOWNTO 0) ;
        residuel_in_4 : IN STD_LOGIC_VECTOR (31 DOWNTO 0) ;
        residuel_in_5 : IN STD_LOGIC_VECTOR (31 DOWNTO 0) ;
        residuel_in_6 : IN STD_LOGIC_VECTOR (31 DOWNTO 0) ;
        residuel_in_7 : IN STD_LOGIC_VECTOR (31 DOWNTO 0) ;
        residuel_in_8 : IN STD_LOGIC_VECTOR (31 DOWNTO 0) ;
        residuel_in_9 : IN STD_LOGIC_VECTOR (31 DOWNTO 0) ;
        residuel_in_10 : IN STD_LOGIC_VECTOR (31 DOWNTO 0) ;
        residuel_in_11 : IN STD_LOGIC_VECTOR (31 DOWNTO 0) ;
        residuel_in_12 : IN STD_LOGIC_VECTOR (31 DOWNTO 0) ;
        residuel_in_13 : IN STD_LOGIC_VECTOR (31 DOWNTO 0) ;
        residuel_in_14 : IN STD_LOGIC_VECTOR (31 DOWNTO 0) ;
        residuel_in_15 : IN STD_LOGIC_VECTOR (31 DOWNTO 0) ;
        residuel_out_0 : OUT STD_LOGIC_VECTOR (31 DOWNTO 0) ;
        residuel_out_1 : OUT STD_LOGIC_VECTOR (31 DOWNTO 0) ;
        residuel_out_2 : OUT STD_LOGIC_VECTOR (31 DOWNTO 0) ;
        residuel_out_3 : OUT STD_LOGIC_VECTOR (31 DOWNTO 0) ;
        residuel_out_4 : OUT STD_LOGIC_VECTOR (31 DOWNTO 0) ;
        residuel_out_5 : OUT STD_LOGIC_VECTOR (31 DOWNTO 0) ;
        residuel_out_6 : OUT STD_LOGIC_VECTOR (31 DOWNTO 0) ;
        residuel_out_7 : OUT STD_LOGIC_VECTOR (31 DOWNTO 0) ;
        residuel_out_8 : OUT STD_LOGIC_VECTOR (31 DOWNTO 0) ;
        residuel_out_9 : OUT STD_LOGIC_VECTOR (31 DOWNTO 0) ;
        residuel_out_10 : OUT STD_LOGIC_VECTOR (31 DOWNTO 0) ;
        residuel_out_11 : OUT STD_LOGIC_VECTOR (31 DOWNTO 0) ;
        residuel_out_12 : OUT STD_LOGIC_VECTOR (31 DOWNTO 0) ;
        residuel_out_13 : OUT STD_LOGIC_VECTOR (31 DOWNTO 0) ;
        residuel_out_14 : OUT STD_LOGIC_VECTOR (31 DOWNTO 0) ;
        residuel_out_15 : OUT STD_LOGIC_VECTOR (31 DOWNTO 0) ;
        DONE : OUT STD_LOGIC
   end component;
  --USER signal declarations added here, as needed for user logic
  -- Signals for user logic slave model s/w accessible register example
  signal slv_reg0                       : std_logic_vector(C_SLV_DWIDTH-1 downto 0);
  signal slv_reg1                       : std_logic_vector(C_SLV_DWIDTH-1 downto 0);
  signal slv_reg2                       : std_logic_vector(C_SLV_DWIDTH-1 downto 0);
  signal slv_reg3                       : std_logic_vector(C_SLV_DWIDTH-1 downto 0);
  signal slv_reg4                       : std_logic_vector(C_SLV_DWIDTH-1 downto 0);
  signal slv_reg5                       : std_logic_vector(C_SLV_DWIDTH-1 downto 0);
  signal slv_reg6                       : std_logic_vector(C_SLV_DWIDTH-1 downto 0);
  signal slv_reg7                       : std_logic_vector(C_SLV_DWIDTH-1 downto 0);
  signal slv_reg8                       : std_logic_vector(C_SLV_DWIDTH-1 downto 0);
  signal slv_reg9                       : std_logic_vector(C_SLV_DWIDTH-1 downto 0);
  signal slv_reg10                      : std_logic_vector(C_SLV_DWIDTH-1 downto 0);
  signal slv_reg11                      : std_logic_vector(C_SLV_DWIDTH-1 downto 0);
  signal slv_reg12                      : std_logic_vector(C_SLV_DWIDTH-1 downto 0);
  signal slv_reg13                      : std_logic_vector(C_SLV_DWIDTH-1 downto 0);
  signal slv_reg14                      : std_logic_vector(C_SLV_DWIDTH-1 downto 0);
  signal slv_reg15                      : std_logic_vector(C_SLV_DWIDTH-1 downto 0);
  signal slv_reg_write_sel              : std_logic_vector(15 downto 0);
  signal slv_reg_read_sel               : std_logic_vector(15 downto 0);
  signal slv_ip2bus_data                : std_logic_vector(C_SLV_DWIDTH-1 downto 0);
  signal slv_read_ack                   : std_logic;
  signal slv_write_ack                  : std_logic;
  signal start_temp                     : std_logic;
   signal slv_reg0_temp                       : std_logic_vector(C_SLV_DWIDTH-1 downto 0);
   signal slv_reg1_temp                       : std_logic_vector(C_SLV_DWIDTH-1 downto 0);
tsignal slv_reg2_temp                       : std_logic_vector(C_SLV_DWIDTH-1 downto 0);
tsignal slv_reg3_temp                       : std_logic_vector(C_SLV_DWIDTH-1 downto 0);
tsignal slv_reg4_temp                       : std_logic_vector(C_SLV_DWIDTH-1 downto 0);
tsignal slv_reg5_temp                       : std_logic_vector(C_SLV_DWIDTH-1 downto 0);
tsignal slv_reg6_temp                       : std_logic_vector(C_SLV_DWIDTH-1 downto 0);
tsignal slv_reg7_temp                       : std_logic_vector(C_SLV_DWIDTH-1 downto 0);
tsignal slv_reg8_temp                       : std_logic_vector(C_SLV_DWIDTH-1 downto 0);
tsignal slv_reg9_temp                       : std_logic_vector(C_SLV_DWIDTH-1 downto 0);
tsignal slv_reg10_temp                       : std_logic_vector(C_SLV_DWIDTH-1 downto 0);
tsignal slv_reg11_temp                       : std_logic_vector(C_SLV_DWIDTH-1 downto 0);
tsignal slv_reg12_temp                       : std_logic_vector(C_SLV_DWIDTH-1 downto 0);
tsignal slv_reg13_temp                       : std_logic_vector(C_SLV_DWIDTH-1 downto 0);
tsignal slv_reg14_temp                       : std_logic_vector(C_SLV_DWIDTH-1 downto 0);
tsignal slv_reg15_temp                       : std_logic_vector(C_SLV_DWIDTH-1 downto 0);
      signal done_temp : std_logic;
t--signaltBus2IP_Clk_1                     :   std_logic;
-- signal  Bus2IP_Resetn_1   :   std_logic;
begin
  --done_temp<='0';
  --USER logic implementation added here
  -- Example code to read/write user logic slave model s/w accessible registers
  -- Note:
  -- The example code presented here is to show you one way of reading/writing
  -- software accessible registers implemented in the user logic slave model.
  -- Each bit of the Bus2IP_WrCE/Bus2IP_RdCE signals is configured to correspond
  -- to one software accessible register by the top level template. For example,
  -- if you have four 32 bit software accessible registers in the user logic,
  -- you are basically operating on the following memory mapped registers:
  --    Bus2IP_WrCE/Bus2IP_RdCE   Memory Mapped Register
  --                     "1000"   C_BASEADDR + 0x0
  --                     "0100"   C_BASEADDR + 0x4
  --                     "0010"   C_BASEADDR + 0x8
  --                     "0001"   C_BASEADDR + 0xC
  slv_reg_write_sel <= Bus2IP_WrCE(15 downto 0);
  slv_reg_read_sel  <= Bus2IP_RdCE(15 downto 0);
  slv_write_ack     <= Bus2IP_WrCE(0) or Bus2IP_WrCE(1) or Bus2IP_WrCE(2) or Bus2IP_WrCE(3) or Bus2IP_WrCE(4) or Bus2IP_WrCE(5) or Bus2IP_WrCE(6) or Bus2IP_WrCE(7) or Bus2IP_WrCE(8) or Bus2IP_WrCE(9) or Bus2IP_WrCE(10) or Bus2IP_WrCE(11) or Bus2IP_WrCE(12) or Bus2IP_WrCE(13) or Bus2IP_WrCE(14) or Bus2IP_WrCE(15);
  slv_read_ack      <= Bus2IP_RdCE(0) or Bus2IP_RdCE(1) or Bus2IP_RdCE(2) or Bus2IP_RdCE(3) or Bus2IP_RdCE(4) or Bus2IP_RdCE(5) or Bus2IP_RdCE(6) or Bus2IP_RdCE(7) or Bus2IP_RdCE(8) or Bus2IP_RdCE(9) or Bus2IP_RdCE(10) or Bus2IP_RdCE(11) or Bus2IP_RdCE(12) or Bus2IP_RdCE(13) or Bus2IP_RdCE(14) or Bus2IP_RdCE(15);
   done_temp<= '1';
--tBus2IP_Clk_1<= '1';
t--Bus2IP_Resetn_1<= '0';
  -- implement slave model software accessible register(s)
  SLAVE_REG_WRITE_PROC : process( Bus2IP_Clk ) is
  begin
    if Bus2IP_Clk'event and Bus2IP_Clk = '1' then
      if Bus2IP_Resetn = '0' then
       start_temp <='0';
tt slv_reg0 <= (others => '0');
        slv_reg1 <= (others => '0');
        slv_reg2 <= (others => '0');
        slv_reg3 <= (others => '0');
        slv_reg4 <= (others => '0');
        slv_reg5 <= (others => '0');
        slv_reg6 <= (others => '0');
        slv_reg7 <= (others => '0');
        slv_reg8 <= (others => '0');
        slv_reg9 <= (others => '0');
        slv_reg10 <= (others => '0');
        slv_reg11 <= (others => '0');
        slv_reg12 <= (others => '0');
        slv_reg13 <= (others => '0');
        slv_reg14 <= (others => '0');
        slv_reg15 <= (others => '0');
      else
        case slv_reg_write_sel is
          when "1000000000000000" =>
            for byte_index in 0 to (C_SLV_DWIDTH/8)-1 loop
              if ( Bus2IP_BE(byte_index) = '1' ) then
                slv_reg0(byte_index*8+7 downto byte_index*8) <= Bus2IP_Data(byte_index*8+7 downto byte_index*8);
              end if;
            end loop;
          when "0100000000000000" =>
                slv_reg1(byte_index*8+7 downto byte_index*8) <= Bus2IP_Data(byte_index*8+7 downto byte_index*8);
              end if;
            end loop;
          when "0010000000000000" =>
                slv_reg2(byte_index*8+7 downto byte_index*8) <= Bus2IP_Data(byte_index*8+7 downto byte_index*8);
              end if;
            end loop;
          when "0001000000000000" =>
                slv_reg3(byte_index*8+7 downto byte_index*8) <= Bus2IP_Data(byte_index*8+7 downto byte_index*8);
              end if;
            end loop;
          when "0000100000000000" =>
                slv_reg4(byte_index*8+7 downto byte_index*8) <= Bus2IP_Data(byte_index*8+7 downto byte_index*8);
              end if;
            end loop;
          when "0000010000000000" =>
                slv_reg5(byte_index*8+7 downto byte_index*8) <= Bus2IP_Data(byte_index*8+7 downto byte_index*8);
              end if;
            end loop;
          when "0000001000000000" =>
                slv_reg6(byte_index*8+7 downto byte_index*8) <= Bus2IP_Data(byte_index*8+7 downto byte_index*8);
              end if;
            end loop;
          when "0000000100000000" =>
                slv_reg7(byte_index*8+7 downto byte_index*8) <= Bus2IP_Data(byte_index*8+7 downto byte_index*8);
              end if;
            end loop;
          when "0000000010000000" =>
                slv_reg8(byte_index*8+7 downto byte_index*8) <= Bus2IP_Data(byte_index*8+7 downto byte_index*8);
              end if;
            end loop;
          when "0000000001000000" =>
                slv_reg9(byte_index*8+7 downto byte_index*8) <= Bus2IP_Data(byte_index*8+7 downto byte_index*8);
              end if;
            end loop;
          when "0000000000100000" =>
                slv_reg10(byte_index*8+7 downto byte_index*8) <= Bus2IP_Data(byte_index*8+7 downto byte_index*8);
              end if;
            end loop;
          when "0000000000010000" =>
                slv_reg11(byte_index*8+7 downto byte_index*8) <= Bus2IP_Data(byte_index*8+7 downto byte_index*8);
              end if;
            end loop;
          when "0000000000001000" =>
                slv_reg12(byte_index*8+7 downto byte_index*8) <= Bus2IP_Data(byte_index*8+7 downto byte_index*8);
              end if;
            end loop;
          when "0000000000000100" =>
                slv_reg13(byte_index*8+7 downto byte_index*8) <= Bus2IP_Data(byte_index*8+7 downto byte_index*8);
              end if;
            end loop;
          when "0000000000000010" =>
                slv_reg14(byte_index*8+7 downto byte_index*8) <= Bus2IP_Data(byte_index*8+7 downto byte_index*8);
              end if;
            end loop;
          when "0000000000000001" =>
                slv_reg15(byte_index*8+7 downto byte_index*8) <= Bus2IP_Data(byte_index*8+7 downto byte_index*8);
tttt start_temp <= '1';
ttttt  else        start_temp<='0';
ttttt
              end if;
            end loop;
          when others => null;
        end case;
      end if;
    end if;
  end process SLAVE_REG_WRITE_PROC;
  -- implement slave model software accessible register(s) read mux
  SLAVE_REG_READ_PROC : process( slv_reg_read_sel, slv_reg0_temp, slv_reg1_temp, slv_reg2_temp, slv_reg3_temp, slv_reg4_temp, slv_reg5_temp, slv_reg6_temp, slv_reg7_temp, slv_reg8_temp, slv_reg9_temp, slv_reg10_temp, slv_reg11_temp, slv_reg12_temp, slv_reg13_temp, slv_reg14_temp, slv_reg15_temp ) is
  begin
    case slv_reg_read_sel is
      when "1000000000000000" => slv_ip2bus_data <= slv_reg0_temp;
      when "0100000000000000" => slv_ip2bus_data <= slv_reg1_temp;
      when "0010000000000000" => slv_ip2bus_data <= slv_reg2_temp;
      when "0001000000000000" => slv_ip2bus_data <= slv_reg3_temp;
      when "0000100000000000" => slv_ip2bus_data <= slv_reg4_temp;
      when "0000010000000000" => slv_ip2bus_data <= slv_reg5_temp;
      when "0000001000000000" => slv_ip2bus_data <= slv_reg6_temp;
      when "0000000100000000" => slv_ip2bus_data <= slv_reg7_temp;
      when "0000000010000000" => slv_ip2bus_data <= slv_reg8_temp;
      when "0000000001000000" => slv_ip2bus_data <= slv_reg9_temp;
      when "0000000000100000" => slv_ip2bus_data <= slv_reg10_temp;
      when "0000000000010000" => slv_ip2bus_data <= slv_reg11_temp;
      when "0000000000001000" => slv_ip2bus_data <= slv_reg12_temp;
      when "0000000000000100" => slv_ip2bus_data <= slv_reg13_temp;
      when "0000000000000010" => slv_ip2bus_data <= slv_reg14_temp;
      when "0000000000000001" => slv_ip2bus_data <= slv_reg15_temp;
      when others => slv_ip2bus_data <= (others => '0');
    end case;
  end process SLAVE_REG_READ_PROC;
  ---------------------------------PORT MAP-------------------------------------
   E_ICT_TOP_LEVEL: ICT_TOP_LEVEL
PORT MAP (tBus2IP_Clk      ,
          tBus2IP_Resetn   ,
          tstart_temp      ,
                slv_reg0 t,
          tslv_reg1 t,
          tslv_reg2 t,       t        t
          tslv_reg3 t,       t
          tslv_reg4 t,       t
        tslv_reg5 t,       t
          tslv_reg6        ,
       t        slv_reg7 t,
          tslv_reg8 t,       t        t
          tslv_reg9 t,       t
        tslv_reg10       ,       t
          tslv_reg11t,       t
          tslv_reg12t,
                slv_reg13       ,
        tslv_reg14       ,       t        t
          tslv_reg15       ,       t
        tslv_reg0_temp t,
        tslv_reg1_tempt,
        tslv_reg2_tempt,
        tslv_reg3_tempt,
        tslv_reg4_temp t,
          tslv_reg5_tempt,
          tslv_reg6_temp t,
          tslv_reg7_temp   ,
          tslv_reg8_tempt,
          tslv_reg9_tempt,
        tslv_reg10_tempt,
          tslv_reg11_tempt,
        tslv_reg12_tempt,
        tslv_reg13_tempt,
          tslv_reg14_tempt,
          tslv_reg15_tempt,
            done_temp
        t
  -- Example code to drive IP to Bus signals
  IP2Bus_Data  <= slv_ip2bus_data when slv_read_ack = '1' else
                  (others => '0');
  IP2Bus_WrAck <= slv_write_ack;
  IP2Bus_RdAck <= slv_read_ack;
  IP2Bus_Error <= '0';
end IMP;
_____________________________________________________
I did the synthesis and everything goes well. But when I generate the bitstream an error appear to me:
Implementation
Translate
[NgdBuild 604] logical block 'proc_module_i/register_ict_16_0/register_ict_16_0/USER_LOGIC_I/E_ICT_TOP_LEVEL' with type 'ICT_TOP_LEVEL' could not be resolved. A pin name misspelling can cause this, a missing edif or ngc file, case mismatch between the block name and the edif or ngc file name, or the misspelling of a type name. Symbol 'ICT_TOP_LEVEL' is not supported in target 'zynq'.
I looked for a solution in the forum but I have not found.
Any Help please?
Thank you.
Mokhtar.
    0 Former Member over 13 years ago
    i didnt read your code but i had a similar error. I dont know the cause of this, but what helped for me is redoing the synthesis. I deleted the whole folder (synth_1 i think) and then did it again.
    Hi Mokhtar, the problem is that for some reason in XST, if you have run a project and then you try to include a new module in your IP block, sometime you have to clean your netlits in order for the XST to start from the beginning and not to re-use the previous netlits that did not contains the new changes you want to introduce. In summary, go to your Hardware tab in EDK and click in the three clean options, that will do the job.
