ZedBoard Hardware Design booting Linux (using petalinux tools) failure
  • Subscribers 359 subscribers
  • Views 509 views
Hi Guys !
I am trying to boot Linux on a ZedBoard but the booting process stopped, hanging on "starting kernel" message.
(working on xapp1078)
I guess there is something wrong with the .dtc ? But I have no idea where exactly because I am a really newbi in all linux and petalinux tools.
Here are the different way I have followed to build BOOT.bin and uimage :
1. hardware design (vivado 2014.4) using tcl script provided in the updated version of the xapp1078 (xapp1078_2014.4 files)
2. software design (sdk 2014.4) : bsp and app for cpu running bare metal app
3. petalinux project :
create a project,
use the hardware file of the previous hardware design,
an dts si automatically generated
i have modified it to add the zedboard peripherals
i have also added two linux apps in the project
build the project (generate uimage, zynq_fsbl.elf, u-boot.elf)
create the boot.bin using the automatically generated zynq_fsbl.elf and u-boot provided in the images files
copy boot.bin and zynq_fsbl.elf on the SD card
thank you for any help !!
Aude
    Hi Aude,
      I would suggest that you try creating a standalone Linux system by using the ZedBoard 2014.4 BSP hosted on the Xilinx Support site:
    http://www.xilinx.com/support/download/index.html/content/xilinx/en/downloadNav/petalinux.html
    You can follow Xilinx UG1156 for instructions on installing and working with PetaLinux BSPs.  Once you have Linux booting correctly on your ZedBoard, you can use that as a model for updating your design for XAPP1078.
    Ron
