ZedBoard Hardware Design Zedboard Sensor Project
  • Subscribers 359 subscribers
  • Views 429 views
Good day,
I am currently working on Zedboard for education purposes. I would like to implement a project in which I will use a force sensitive resistor sensor and then I will have the force value written on OLED which is placed on Zedboard. The following is a picture from the set up. Sensor signal is entered to Zedboard through 12 bit SPI ADC. However, I could not find any tutorial explaining usage of sensor with Zedboard. I think I should use SPI block but I do not know how to use it and could not find any tutorial about that, either.
Can you help me about how can I read this sensor and write its value on display?
Thanks.image
    If your application runs under Linux I would take a look at the 'Wind River Pulsar Linux OS with SPI Peripheral Integration reference design for the Industrial IoT Starter Kit.
    You can download it here: http://zedboard.org/support/design/13591/116
    If you are looking for a 'bare metal' application these links might be helpful:
    http://zedboard.org/content/spi-controller-c-code-example
    http://zedboard.org/content/spi-example
    http://zedboard.org/content/configuring-zynq-spi-interface
    -Gary
