ZedBoard Hardware Design PIN Clocks Zedboard
  • Subscribers 358 subscribers
  • Views 2182 views
PIN Clocks Zedboard
DDina
DDina over 4 years ago
Hi all
I want to use an external clock with zedboard
I used in my expriments two zedboards.
First board generates PL clk 100MHz  and outputs this signal using "JA4" (which is AA9 on the FPGA)
The second zedboard has as input clk using "JA4" (which is AA9 on the FPGA) and used to clock a counter but it's not working correctly
I don't know if I used this pin correctly
# Clock Source - # "JA4"
set_property IOSTANDARD LVCMOS33 [get_ports clk]
set_property PACKAGE_PIN AA9 [get_ports clk]
set_property CLOCK_DEDICATED_ROUTE FALSE [get_nets {clk}];
Please any suggestion
    0 e14 Contributor over 2 years ago
    Hey,
    If you can tell. how did you observe the clock from "JA4" (which i guess is from PMOD). Did u connect the oscilloscope probe directly to JA4 pins using jumper wires?
