ZedBoard Hardware Design Issues with Custom Memory Interface
  • Replies 7 replies
  • Subscribers 356 subscribers
  • Views 2209 views
dniemann17
dniemann17 over 2 years ago
Hello!
We are currently using a Zedboard to create a custom AXI memory and register interface from a verilog file.
The memory interface is 16K words and uses AXI4 FULL, and the register interface is 32K words and uses AXI Lite
As of writing, we are able to do the following with these interfaces using a CLI:
  • Read custom register interface
  • Write to custom register interface
    • Confirm data written can be read again
  • Read custom memory interface
We are having issues trying to write to the custom memory interface.
All that the software CLI does is parse out an address and use Xil_In/Xil_Out to read/write to ZedBoard memory
  • This feature has been tested extensively on other projects and other sections of memory on the ZedBoard, all of which work perfectly normally
We believe this is a Verilog error and want advice/help with testing and simulating the AXI bus to try and find the issue.
We looked for an AXI bus testing solution, but the posts on the Xilinx website were all out of date and unable to be followed (we run 2023.2 and the guides were written for 2019.2).
Contained below is a list of files associated with a block diagram of our project (I've had to rename them to .txt files to upload).
xilinx_tdpram_1024x36.v                     ====>   Base single memory block file
dig_core_dpram_32.v                          ====>   Top memory file (contains 4 rams)
proto_core_top_regs_ex.v                   ====>   Top register file
pocket_interface_v1_0.v                      ====>   Top reg/mem interface file
pocket_interface_v1_0_S00_AXI.v      ====>   Register AXI interface file
pocket_interface_v1_0_S01_AXI.v      ====>   Memory AXI interface file
Currently it seems that pocket_interface_v1_0_S01_AXI.v is the main problem with the temporary write address or "axi_awaddr" being the likely cause, but we can't be fully sure.
Any help with the error or testing methodology would be appreciated.
Daniel
Fullscreen xilinx_tdpram_1024x36.txt Download
// True Dual Port Ram
// Uses RAM36E1 Ram
module xilinx_tdpram_1024x36(
  input         clk_a,   // Clock Port A
  input         reset_a, // Sync active high reset
  input         en_a,    // Enable operations Port A
  input         regce_a, // Output Register Clock Enable Port A
  input   [3:0] wren_a,  // Write Enables Port A
  input   [9:0] addr_a,  // Address Port A
  input  [35:0] din_a,   // Data Port A
  output [35:0] dout_a,  // Data Port A
  input         clk_b,   // Clock Port A
  input         reset_b, // Sync active high reset
  input         en_b,    // Enable operations Port B
  input         regce_b, // Output Register Clock Enable Port B
  input   [3:0] wren_b,  // Write Enables Port B
  input   [9:0] addr_b,  // Address Port B
  input  [35:0] din_b,   // Data Port B
  output [35:0] dout_b   // Data Port B
parameter USE_OUTPUT_REG_A = 1'b0;
parameter USE_OUTPUT_REG_B = 1'b0;
wire  [31:0]  DOA     ;
wire  [3:0]   DOPA    ;
wire  [31:0]  DOB     ;
wire  [3:0]   DOPB    ;
wire  [31:0]  DIA  = din_a[31:0]  ;
wire  [3:0]   DIPA = din_a[35:32] ;
wire  [31:0]  DIB  = din_b[31:0]  ;
wire  [3:0]   DIPB = din_b[35:32] ;
wire  [15:0]  ADDRA  = { 1'b1, addr_a[9:0], 5'b11111 };
wire  [15:0]  ADDRB  = { 1'b1, addr_b[9:0], 5'b11111 };
wire [3:0] WEA   = wren_a[3:0];
wire [7:0] WEBWE = { wren_b[3:0], wren_b[3:0]};
assign dout_a = {DOPA[3:0], DOA[31:0]};
assign dout_b = {DOPB[3:0], DOB[31:0]};
RAMB36E1 #(
   .RAM_MODE               ( "TDP"             )  // RAM Mode: "SDP" or "TDP"
  ,.SIM_COLLISION_CHECK    ( "GENERATE_X_ONLY" )  // Colision check: Values ("ALL", "WARNING_ONLY", "GENERATE_X_ONLY" or "NONE")
  ,.SIM_DEVICE             ( "7SERIES"         )  // Simulation Device: Must be set to "7SERIES" for simulation behavior
  ,.DOA_REG                ( USE_OUTPUT_REG_A    )  // 1=Use output Reg
  ,.DOB_REG                ( USE_OUTPUT_REG_B    )  // 1=Use output Reg
  ,.READ_WIDTH_A           ( 36 ) // Valid values are 1, 2, 4, 9, 18, or 36
  ,.READ_WIDTH_B           ( 36 )
  ,.WRITE_WIDTH_A          ( 36 )
  ,.WRITE_WIDTH_B          ( 36 )
  ) RAM_I (
  // Port A
   .CLKARDCLK     (clk_a)       // input         Port A Clock
  ,.RSTRAMARSTRAM (reset_a)     // input         Port A set/reset
  ,.RSTREGARSTREG (reset_a)     // input         Port A Output Register set/reset
  ,.ENARDEN       (en_a)        // input         Port A RAM Enable
  ,.REGCEAREGCE   (regce_a)     // input         Port A Output Register Clock Enable
  ,.ADDRARDADDR   (ADDRA[15:0]) // input  [15:0] Port A Address
  ,.DIADI         (DIA[31:0])   // input  [31:0] Port A Data Input Bus
  ,.DIPADIP       (DIPA[3:0])   // input   [3:0] Port A Data Input Parity Bus
  ,.WEA           (WEA[3:0])    // input   [3:0] Port A Write Enable
  ,.DOADO         (DOA[31:0])   // output [31:0] Port A Data Output Bus
  ,.DOPADOP       (DOPA[3:0])   // output  [3:0] Port A Data Output Parity Bus
  // Port B
  ,.CLKBWRCLK     (clk_b)       // input         Port B Clock
  ,.RSTRAMB       (reset_b)     // input         Port B set/reset
  ,.RSTREGB       (reset_b)     // input         Port B Output Register set/reset
  ,.REGCEB        (regce_b)     // input         Port B Output Register Clock Enable
  ,.ENBWREN       (en_b)        // input         Port B RAM Enable
  ,.WEBWE         (WEBWE[7:0])  // input   [7:0] Port B Write Enable
  ,.ADDRBWRADDR   (ADDRB[15:0]) // input  [15:0] Port B Address
  ,.DIBDI         (DIB[31:0])   // input  [31:0] Port B Data Input Bus
  ,.DIPBDIP       (DIPB[3:0])   // input   [3:0] Port B Data Input Parity Bus
  ,.DOBDO         (DOB[31:0])   // output [31:0] Port B Data Output Bus
  ,.DOPBDOP       (DOPB[3:0])   // output  [3:0] Port B Data Output Parity Bus
  ,.CASCADEINA    (1'b0)      // input
  ,.CASCADEOUTA   ()          // output
  ,.CASCADEINB    (1'b0)      // input
  ,.CASCADEOUTB   ()          // output
  ,.INJECTDBITERR (1'b0)      // input Inject a Double Bit Error
  ,.INJECTSBITERR (1'b0)      // input Inject a Single Bit Error
  ,.DBITERR       ()          // output        Double Bit Error Status
  ,.ECCPARITY     ()          // output  [7:0] ECC Encoder Output Bus
  ,.RDADDRECC     ()          // output  [8:0] ECC Read Address
  ,.SBITERR       ()          // output        Single Bit Error Status
endmodule // xilinx_sdpram_1024x36
Fullscreen pocket_interface_v1_0.txt Download
`timescale 1 ns / 1 ps
	module pocket_interface_v1_0 #
		// Users to add parameters here
		parameter integer USER_REG_ADDR_WIDTH	= 10,
		parameter integer USER_IRAM_ADDR_WIDTH	= 12,
		// User parameters ends
		// Do not modify the parameters beyond this line
		// Parameters of Axi Slave Bus Interface S00_AXI
		parameter integer C_S00_AXI_DATA_WIDTH	= 32,
		parameter integer C_S00_AXI_ADDR_WIDTH	= 12,
		// Parameters of Axi Slave Bus Interface S01_AXI
		parameter integer C_S01_AXI_ID_WIDTH	= 12,
		parameter integer C_S01_AXI_DATA_WIDTH	= 32,
		parameter integer C_S01_AXI_ADDR_WIDTH	= 14,
		parameter integer C_S01_AXI_AWUSER_WIDTH	= 0,
		parameter integer C_S01_AXI_ARUSER_WIDTH	= 0,
		parameter integer C_S01_AXI_WUSER_WIDTH	= 0,
		parameter integer C_S01_AXI_RUSER_WIDTH	= 0,
		parameter integer C_S01_AXI_BUSER_WIDTH	= 0
		// Users to add ports here
// Register Interface
output wire        preg_wren,    // Register Write Enable
output wire  [3:0] preg_byte_en, // Register Byte Write Enables
output wire  [USER_REG_ADDR_WIDTH-1:0] preg_addr,    // Register Write Address
output wire [31:0] preg_wdata,   // Register Write data
output wire  [USER_REG_ADDR_WIDTH-1:0] preg_raddr,   // Register Read Address
input  wire [31:0] preg_rdata,   // Register Read data
// TDP RAM Interface
output wire        tdp_en_a,   // Enable operations RAM Port A
output wire  [3:0] tdp_wren_a, // Write Enables RAM Port A
output wire  [USER_IRAM_ADDR_WIDTH-1:0] tdp_addr_a, // Address RAM Port A
output wire [31:0] tdp_din_a,  // Write Data RAM Port A
input  wire [31:0] tdp_dout_a, // Read Data RAM Port A
		// User ports ends
		// Do not modify the ports beyond this line
		// Ports of Axi Slave Bus Interface S00_AXI
		input wire  s00_axi_aclk,
		input wire  s00_axi_aresetn,
		input wire [C_S00_AXI_ADDR_WIDTH-1 : 0] s00_axi_awaddr,
		input wire [2 : 0] s00_axi_awprot,
		input wire  s00_axi_awvalid,
		output wire  s00_axi_awready,
		input wire [C_S00_AXI_DATA_WIDTH-1 : 0] s00_axi_wdata,
		input wire [(C_S00_AXI_DATA_WIDTH/8)-1 : 0] s00_axi_wstrb,
		input wire  s00_axi_wvalid,
		output wire  s00_axi_wready,
		output wire [1 : 0] s00_axi_bresp,
		output wire  s00_axi_bvalid,
		input wire  s00_axi_bready,
		input wire [C_S00_AXI_ADDR_WIDTH-1 : 0] s00_axi_araddr,
		input wire [2 : 0] s00_axi_arprot,
		input wire  s00_axi_arvalid,
		output wire  s00_axi_arready,
		output wire [C_S00_AXI_DATA_WIDTH-1 : 0] s00_axi_rdata,
		output wire [1 : 0] s00_axi_rresp,
		output wire  s00_axi_rvalid,
		input wire  s00_axi_rready,
		// Ports of Axi Slave Bus Interface S01_AXI
		input wire  s01_axi_aclk,
		input wire  s01_axi_aresetn,
		input wire [C_S01_AXI_ID_WIDTH-1 : 0] s01_axi_awid,
		input wire [C_S01_AXI_ADDR_WIDTH-1 : 0] s01_axi_awaddr,
		input wire [7 : 0] s01_axi_awlen,
		input wire [2 : 0] s01_axi_awsize,
		input wire [1 : 0] s01_axi_awburst,
		input wire  s01_axi_awlock,
		input wire [3 : 0] s01_axi_awcache,
		input wire [2 : 0] s01_axi_awprot,
		input wire [3 : 0] s01_axi_awqos,
		input wire [3 : 0] s01_axi_awregion,
		input wire [C_S01_AXI_AWUSER_WIDTH-1 : 0] s01_axi_awuser,
		input wire  s01_axi_awvalid,
		output wire  s01_axi_awready,
		input wire [C_S01_AXI_DATA_WIDTH-1 : 0] s01_axi_wdata,
		input wire [(C_S01_AXI_DATA_WIDTH/8)-1 : 0] s01_axi_wstrb,
		input wire  s01_axi_wlast,
		input wire [C_S01_AXI_WUSER_WIDTH-1 : 0] s01_axi_wuser,
		input wire  s01_axi_wvalid,
		output wire  s01_axi_wready,
		output wire [C_S01_AXI_ID_WIDTH-1 : 0] s01_axi_bid,
		output wire [1 : 0] s01_axi_bresp,
		output wire [C_S01_AXI_BUSER_WIDTH-1 : 0] s01_axi_buser,
		output wire  s01_axi_bvalid,
		input wire  s01_axi_bready,
		input wire [C_S01_AXI_ID_WIDTH-1 : 0] s01_axi_arid,
		input wire [C_S01_AXI_ADDR_WIDTH-1 : 0] s01_axi_araddr,
		input wire [7 : 0] s01_axi_arlen,
		input wire [2 : 0] s01_axi_arsize,
		input wire [1 : 0] s01_axi_arburst,
		input wire  s01_axi_arlock,
		input wire [3 : 0] s01_axi_arcache,
		input wire [2 : 0] s01_axi_arprot,
		input wire [3 : 0] s01_axi_arqos,
		input wire [3 : 0] s01_axi_arregion,
		input wire [C_S01_AXI_ARUSER_WIDTH-1 : 0] s01_axi_aruser,
		input wire  s01_axi_arvalid,
		output wire  s01_axi_arready,
		output wire [C_S01_AXI_ID_WIDTH-1 : 0] s01_axi_rid,
		output wire [C_S01_AXI_DATA_WIDTH-1 : 0] s01_axi_rdata,
		output wire [1 : 0] s01_axi_rresp,
		output wire  s01_axi_rlast,
		output wire [C_S01_AXI_RUSER_WIDTH-1 : 0] s01_axi_ruser,
		output wire  s01_axi_rvalid,
		input wire  s01_axi_rready
// Instantiation of Axi Bus Interface S00_AXI
	pocket_interface_v1_0_S00_AXI # (
		.USER_REG_ADDR_WIDTH(USER_REG_ADDR_WIDTH),
		.C_S_AXI_DATA_WIDTH(C_S00_AXI_DATA_WIDTH),
		.C_S_AXI_ADDR_WIDTH(C_S00_AXI_ADDR_WIDTH)
	) pocket_interface_v1_0_S00_AXI_inst (
   .preg_wren    (preg_wren)         // output wire        Register Write Enable
  ,.preg_byte_en (preg_byte_en[3:0]) // output wire  [3:0] Register Byte Write Enables
  ,.preg_addr    (preg_addr[USER_REG_ADDR_WIDTH-1:0])    // output wire  [4:0] Register Address
  ,.preg_wdata   (preg_wdata[31:0])  // output wire [31:0] Register Write data
  ,.preg_raddr   (preg_raddr[USER_REG_ADDR_WIDTH-1:0])   // output wire  [4:0] Register Read Address
  ,.preg_rdata   (preg_rdata[31:0])  // input  wire [31:0] Register Read data
		,.S_AXI_ACLK(s00_axi_aclk),
		.S_AXI_ARESETN(s00_axi_aresetn),
		.S_AXI_AWADDR(s00_axi_awaddr),
		.S_AXI_AWPROT(s00_axi_awprot),
		.S_AXI_AWVALID(s00_axi_awvalid),
		.S_AXI_AWREADY(s00_axi_awready),
		.S_AXI_WDATA(s00_axi_wdata),
		.S_AXI_WSTRB(s00_axi_wstrb),
		.S_AXI_WVALID(s00_axi_wvalid),
		.S_AXI_WREADY(s00_axi_wready),
		.S_AXI_BRESP(s00_axi_bresp),
		.S_AXI_BVALID(s00_axi_bvalid),
		.S_AXI_BREADY(s00_axi_bready),
		.S_AXI_ARADDR(s00_axi_araddr),
		.S_AXI_ARPROT(s00_axi_arprot),
		.S_AXI_ARVALID(s00_axi_arvalid),
		.S_AXI_ARREADY(s00_axi_arready),
		.S_AXI_RDATA(s00_axi_rdata),
		.S_AXI_RRESP(s00_axi_rresp),
		.S_AXI_RVALID(s00_axi_rvalid),
		.S_AXI_RREADY(s00_axi_rready)
// Instantiation of Axi Bus Interface S01_AXI
	pocket_interface_v1_0_S01_AXI # (
		.USER_IRAM_ADDR_WIDTH(USER_IRAM_ADDR_WIDTH),
		.C_S_AXI_ID_WIDTH(C_S01_AXI_ID_WIDTH),
		.C_S_AXI_DATA_WIDTH(C_S01_AXI_DATA_WIDTH),
		.C_S_AXI_ADDR_WIDTH(C_S01_AXI_ADDR_WIDTH),
		.C_S_AXI_AWUSER_WIDTH(C_S01_AXI_AWUSER_WIDTH),
		.C_S_AXI_ARUSER_WIDTH(C_S01_AXI_ARUSER_WIDTH),
		.C_S_AXI_WUSER_WIDTH(C_S01_AXI_WUSER_WIDTH),
		.C_S_AXI_RUSER_WIDTH(C_S01_AXI_RUSER_WIDTH),
		.C_S_AXI_BUSER_WIDTH(C_S01_AXI_BUSER_WIDTH)
	) pocket_interface_v1_0_S01_AXI_inst (
   .tdp_en_a   (tdp_en_a)         // output wire        Enable operations RAM Port A
  ,.tdp_wren_a (tdp_wren_a[3:0])  // output wire  [3:0] Write Enables RAM Port A
  ,.tdp_addr_a (tdp_addr_a[USER_IRAM_ADDR_WIDTH-1:0])  // output wire  [9:0] Address RAM Port A
  ,.tdp_din_a  (tdp_din_a[31:0])  // output wire [31:0] Write Data RAM Port A
  ,.tdp_dout_a (tdp_dout_a[31:0]) // input  wire [31:0] Read Data RAM Port A
		,.S_AXI_ACLK(s01_axi_aclk),
		.S_AXI_ARESETN(s01_axi_aresetn),
		.S_AXI_AWID(s01_axi_awid),
		.S_AXI_AWADDR(s01_axi_awaddr),
		.S_AXI_AWLEN(s01_axi_awlen),
		.S_AXI_AWSIZE(s01_axi_awsize),
		.S_AXI_AWBURST(s01_axi_awburst),
		.S_AXI_AWLOCK(s01_axi_awlock),
		.S_AXI_AWCACHE(s01_axi_awcache),
		.S_AXI_AWPROT(s01_axi_awprot),
		.S_AXI_AWQOS(s01_axi_awqos),
		.S_AXI_AWREGION(s01_axi_awregion),
		.S_AXI_AWUSER(s01_axi_awuser),
		.S_AXI_AWVALID(s01_axi_awvalid),
		.S_AXI_AWREADY(s01_axi_awready),
		.S_AXI_WDATA(s01_axi_wdata),
		.S_AXI_WSTRB(s01_axi_wstrb),
		.S_AXI_WLAST(s01_axi_wlast),
		.S_AXI_WUSER(s01_axi_wuser),
		.S_AXI_WVALID(s01_axi_wvalid),
		.S_AXI_WREADY(s01_axi_wready),
		.S_AXI_BID(s01_axi_bid),
		.S_AXI_BRESP(s01_axi_bresp),
		.S_AXI_BUSER(s01_axi_buser),
		.S_AXI_BVALID(s01_axi_bvalid),
		.S_AXI_BREADY(s01_axi_bready),
		.S_AXI_ARID(s01_axi_arid),
		.S_AXI_ARADDR(s01_axi_araddr),
		.S_AXI_ARLEN(s01_axi_arlen),
		.S_AXI_ARSIZE(s01_axi_arsize),
		.S_AXI_ARBURST(s01_axi_arburst),
		.S_AXI_ARLOCK(s01_axi_arlock),
		.S_AXI_ARCACHE(s01_axi_arcache),
		.S_AXI_ARPROT(s01_axi_arprot),
		.S_AXI_ARQOS(s01_axi_arqos),
		.S_AXI_ARREGION(s01_axi_arregion),
		.S_AXI_ARUSER(s01_axi_aruser),
		.S_AXI_ARVALID(s01_axi_arvalid),
		.S_AXI_ARREADY(s01_axi_arready),
		.S_AXI_RID(s01_axi_rid),
		.S_AXI_RDATA(s01_axi_rdata),
		.S_AXI_RRESP(s01_axi_rresp),
		.S_AXI_RLAST(s01_axi_rlast),
		.S_AXI_RUSER(s01_axi_ruser),
		.S_AXI_RVALID(s01_axi_rvalid),
		.S_AXI_RREADY(s01_axi_rready)
	// Add user logic here
	// User logic ends
endmodule // pocket_interface_v1_0
Fullscreen dig_core_dpram_32.txt Download
// Change Feb. 17, 2020.  Made RAM access little Endian
module dig_core_dpram_32 #(
parameter OADDR_BITS = 12 //  Num address bits output RAM
  input                  clk,        // Bus Clock
  input                  reset,      // Sync active high reset
  input                  ram_cs,     // RAM Bus Chip Select
  input           [13:0] ram_addr,   // RAM Bus Address
  input                  ram_wr,     // RAM Bus Write
  input                  ram_rd,     // RAM Bus Read
  input            [3:0] ram_eb,     // RAM Bus Enable Bytes
  input           [31:0] ram_w_data, // RAM Bus Write Data
  output reg      [31:0] ram_r_data  // RAM Bus Read Data
  wire                	clk2pow25 = clk;       // System clock: 2^25 Hz
  wire                	reset_clk2pow25 = reset; // Sync active high reset
  wire                  wr_en_obuf = 'd0;      // Buffer Write Enable
  wire [OADDR_BITS-1:0] wr_addr_obuf = 'd0;    // Buffer Address
  wire           [31:0] wr_data_obuf = 'd0;    // Buffer Data
wire tdp_clk_a   = clk;
wire tdp_reset_a = reset;
wire tdp_en_a_0  = ram_cs & (ram_rd | ram_wr) & ~ram_addr[13] & ~ram_addr[12];		// Enables for RAM ports?
wire tdp_en_a_1  = ram_cs & (ram_rd | ram_wr) & ~ram_addr[13] &  ram_addr[12];
wire tdp_en_a_2  = ram_cs & (ram_rd | ram_wr) &  ram_addr[13] & ~ram_addr[12];
wire tdp_en_a_3  = ram_cs & (ram_rd | ram_wr) &  ram_addr[13] &  ram_addr[12];
wire [3:0] tdp_wren_a = ram_eb[3:0];	// Ram Bus enable bits
//assign tdp_wren_a[3] =  ram_addr[0] & ram_eb[1] & ram_wr;	// R/W Enable for RAM Ports?
//assign tdp_wren_a[2] =  ram_addr[0] & ram_eb[0] & ram_wr;
///assign tdp_wren_a[1] = ~ram_addr[0] & ram_eb[1] & ram_wr;
//assign tdp_wren_a[0] = ~ram_addr[0] & ram_eb[0] & ram_wr;
wire [9:0] tdp_addr_a = ram_addr[11:2];
wire [35:0] tdp_din_a = {4'd0, ram_w_data[31:0]};		// 4 parity bits tied off to 0 (for now) bottom 32 bits is RAM data
wire [35:0] tdp_dout_a_0;
wire [35:0] tdp_dout_a_1;
wire [35:0] tdp_dout_a_2;
wire [35:0] tdp_dout_a_3;
wire [35:0] tdp_dout_a = ram_addr[13] ?
                         (ram_addr[12] ? tdp_dout_a_3 : tdp_dout_a_2 ) :
                         (ram_addr[12] ? tdp_dout_a_1 : tdp_dout_a_0 ) ;
// RAM Port B options
wire [11:0] i_wr_addr  = {{(12-OADDR_BITS){1'b0}},
                           wr_addr_obuf[OADDR_BITS-1:0]};
wire        tdp_en_b_0 = wr_en_obuf & ~i_wr_addr[11] & ~i_wr_addr[10];
wire        tdp_en_b_1 = wr_en_obuf & ~i_wr_addr[11] &  i_wr_addr[10];
wire        tdp_en_b_2 = wr_en_obuf &  i_wr_addr[11] & ~i_wr_addr[10];
wire        tdp_en_b_3 = wr_en_obuf &  i_wr_addr[11] &  i_wr_addr[10];
wire  [3:0] tdp_wren_b = {4{wr_en_obuf}};
wire  [9:0] tdp_addr_b = i_wr_addr[9:0];
wire [35:0] tdp_din_b  = {4'd0, wr_data_obuf[31:0]};
wire [35:0] tdp_dout_b_0;
wire [35:0] tdp_dout_b_1;
wire [35:0] tdp_dout_b_2;
wire [35:0] tdp_dout_b_3;
xilinx_tdpram_1024x36 RAM_I_0 (
   .clk_a   (tdp_clk_a)          // input         Clock Port A
  ,.reset_a (tdp_reset_a)        // input         Sync active high reset
  ,.en_a    (tdp_en_a_0)         // input         Enable operations Port A
  ,.regce_a (1'b0)               // input         Output Register Clock Enable Port A - Not using OutReg
  ,.wren_a  (tdp_wren_a[3:0])    // input   [3:0] Write Enables Port A
  ,.addr_a  (tdp_addr_a[9:0])    // input   [9:0] Address Port A
  ,.din_a   (tdp_din_a[35:0])    // input  [35:0] Data Port A
  ,.dout_a  (tdp_dout_a_0[35:0]) // output [35:0] Data Port A
  ,.clk_b   (clk2pow25)          // input         Clock Port A
  ,.reset_b (reset_clk2pow25)    // input         Sync active high reset
  ,.en_b    (tdp_en_b_0)         // input         Enable operations Port B
  ,.regce_b (1'b0)               // input         Output Register Clock Enable Port B
  ,.wren_b  (tdp_wren_b[3:0])    // input   [3:0] Write Enables Port B
  ,.addr_b  (tdp_addr_b[9:0])    // input   [9:0] Address Port B
  ,.din_b   (tdp_din_b[35:0])    // input  [35:0] Data Port B
  ,.dout_b  (tdp_dout_b_0[35:0]) // output [35:0] Data Port B
xilinx_tdpram_1024x36 RAM_I_1 (
  ,.en_a    (tdp_en_a_1)         // input         Enable operations Port A
  ,.dout_a  (tdp_dout_a_1[35:0]) // output [35:0] Data Port A
  ,.en_b    (tdp_en_b_1)         // input         Enable operations Port B
  ,.dout_b  (tdp_dout_b_1[35:0]) // output [35:0] Data Port B
xilinx_tdpram_1024x36 RAM_I_2 (
  ,.en_a    (tdp_en_a_2)         // input         Enable operations Port A
  ,.dout_a  (tdp_dout_a_2[35:0]) // output [35:0] Data Port A
  ,.en_b    (tdp_en_b_2)         // input         Enable operations Port B
  ,.dout_b  (tdp_dout_b_2[35:0]) // output [35:0] Data Port B
xilinx_tdpram_1024x36 RAM_I_3 (
  ,.en_a    (tdp_en_a_3)         // input         Enable operations Port A
  ,.dout_a  (tdp_dout_a_3[35:0]) // output [35:0] Data Port A
  ,.en_b    (tdp_en_b_3)         // input         Enable operations Port B
  ,.dout_b  (tdp_dout_b_3[35:0]) // output [35:0] Data Port B
always @ (posedge tdp_clk_a)
  begin
  if (tdp_reset_a)
    begin
    ram_r_data <= 0;
    end
  else
    begin
    ram_r_data[31:0] <=  tdp_dout_a[31:0];
    end
  end
endmodule // dig_core_dpram_32
Fullscreen pocket_interface_v1_0_S00_AXI.txt Download
	module pocket_interface_v1_0_S00_AXI #
		// Width of S_AXI data bus
		parameter integer C_S_AXI_DATA_WIDTH	= 32,
		// Width of S_AXI address bus
		parameter integer C_S_AXI_ADDR_WIDTH	= 12
		// User ports ends
		// Global Clock Signal
		input wire  S_AXI_ACLK,
		// Global Reset Signal. This Signal is Active LOW
		input wire  S_AXI_ARESETN,
		// Write address (issued by master, acceped by Slave)
		input wire [C_S_AXI_ADDR_WIDTH-1 : 0] S_AXI_AWADDR,
		// Write channel Protection type. This signal indicates the
    		// privilege and security level of the transaction, and whether
    		// the transaction is a data access or an instruction access.
		input wire [2 : 0] S_AXI_AWPROT,
		// Write address valid. This signal indicates that the master signaling
    		// valid write address and control information.
		input wire  S_AXI_AWVALID,
		// Write address ready. This signal indicates that the slave is ready
    		// to accept an address and associated control signals.
		output wire  S_AXI_AWREADY,
		// Write data (issued by master, acceped by Slave)
		input wire [C_S_AXI_DATA_WIDTH-1 : 0] S_AXI_WDATA,
		// Write strobes. This signal indicates which byte lanes hold
    		// valid data. There is one write strobe bit for each eight
    		// bits of the write data bus.
		input wire [(C_S_AXI_DATA_WIDTH/8)-1 : 0] S_AXI_WSTRB,
		// Write valid. This signal indicates that valid write
    		// data and strobes are available.
		input wire  S_AXI_WVALID,
		// Write ready. This signal indicates that the slave
    		// can accept the write data.
		output wire  S_AXI_WREADY,
		// Write response. This signal indicates the status
    		// of the write transaction.
		output wire [1 : 0] S_AXI_BRESP,
		// Write response valid. This signal indicates that the channel
    		// is signaling a valid write response.
		output wire  S_AXI_BVALID,
		// Response ready. This signal indicates that the master
    		// can accept a write response.
		input wire  S_AXI_BREADY,
		// Read address (issued by master, acceped by Slave)
		input wire [C_S_AXI_ADDR_WIDTH-1 : 0] S_AXI_ARADDR,
		// Protection type. This signal indicates the privilege
    		// and security level of the transaction, and whether the
    		// transaction is a data access or an instruction access.
		input wire [2 : 0] S_AXI_ARPROT,
		// Read address valid. This signal indicates that the channel
    		// is signaling valid read address and control information.
		input wire  S_AXI_ARVALID,
		// Read address ready. This signal indicates that the slave is
    		// ready to accept an address and associated control signals.
		output wire  S_AXI_ARREADY,
		// Read data (issued by slave)
		output wire [C_S_AXI_DATA_WIDTH-1 : 0] S_AXI_RDATA,
		// Read response. This signal indicates the status of the
    		// read transfer.
		output wire [1 : 0] S_AXI_RRESP,
		// Read valid. This signal indicates that the channel is
    		// signaling the required read data.
		output wire  S_AXI_RVALID,
		// Read ready. This signal indicates that the master can
    		// accept the read data and response information.
		input wire  S_AXI_RREADY
	// AXI4LITE signals
	reg [C_S_AXI_ADDR_WIDTH-1 : 0] 	axi_awaddr;
	reg  	axi_awready;
	reg  	axi_wready;
	reg [1 : 0] 	axi_bresp;
	reg  	axi_bvalid;
	reg [C_S_AXI_ADDR_WIDTH-1 : 0] 	axi_araddr;
	reg  	axi_arready;
	reg [C_S_AXI_DATA_WIDTH-1 : 0] 	axi_rdata;
	reg [1 : 0] 	axi_rresp;
	reg  	axi_rvalid;
	// Example-specific design signals
	// local parameter for addressing 32 bit / 64 bit C_S_AXI_DATA_WIDTH
	// ADDR_LSB is used for addressing 32/64 bit registers/memories
	// ADDR_LSB = 2 for 32 bits (n downto 2)
	// ADDR_LSB = 3 for 64 bits (n downto 3)
	localparam integer ADDR_LSB = (C_S_AXI_DATA_WIDTH/32) + 1;
	//localparam integer OPT_MEM_ADDR_BITS = 4;
	localparam integer OPT_MEM_ADDR_BITS = USER_REG_ADDR_WIDTH - 1; // up to 1024 registers
	//-- Signals for user logic register space example
	//-- Number of Slave Registers 32
	wire	 slv_reg_rden;
	wire	 slv_reg_wren;
//	reg [C_S_AXI_DATA_WIDTH-1:0]	 reg_data_out;
	integer	 byte_index;
	reg	 aw_en;
	// I/O Connections assignments
	assign S_AXI_AWREADY	= axi_awready;
	assign S_AXI_WREADY	= axi_wready;
	assign S_AXI_BRESP	= axi_bresp;
	assign S_AXI_BVALID	= axi_bvalid;
	assign S_AXI_ARREADY	= axi_arready;
	assign S_AXI_RDATA	= axi_rdata;
	assign S_AXI_RRESP	= axi_rresp;
	assign S_AXI_RVALID	= axi_rvalid;
	// Implement axi_awready generation
	// axi_awready is asserted for one S_AXI_ACLK clock cycle when both
	// S_AXI_AWVALID and S_AXI_WVALID are asserted. axi_awready is
	// de-asserted when reset is low.
	always @( posedge S_AXI_ACLK )
	begin
	  if ( S_AXI_ARESETN == 1'b0 )
	    begin
	      axi_awready <= 1'b0;
	      aw_en <= 1'b1;
	    end
	  else
	    begin
	      if (~axi_awready && S_AXI_AWVALID && S_AXI_WVALID && aw_en)
	        begin
	          // slave is ready to accept write address when
	          // there is a valid write address and write data
	          // on the write address and data bus. This design
	          // expects no outstanding transactions.
	          axi_awready <= 1'b1;
	          aw_en <= 1'b0;
	        end
	        else if (S_AXI_BREADY && axi_bvalid)
	            begin
	              aw_en <= 1'b1;
	            end
	      else
	        begin
	        end
	    end
	end
	// Implement axi_awaddr latching
	// This process is used to latch the address when both
	// S_AXI_AWVALID and S_AXI_WVALID are valid.
	begin
	    begin
	      axi_awaddr <= 0;
	    end
	  else
	    begin
	        begin
	          // Write Address latching
	          axi_awaddr <= S_AXI_AWADDR;
	        end
	    end
	end
	// Implement axi_wready generation
	// axi_wready is asserted for one S_AXI_ACLK clock cycle when both
	// S_AXI_AWVALID and S_AXI_WVALID are asserted. axi_wready is
	begin
	    begin
	      axi_wready <= 1'b0;
	    end
	  else
	    begin
	      if (~axi_wready && S_AXI_WVALID && S_AXI_AWVALID && aw_en )
	        begin
	          // slave is ready to accept write data when
	          axi_wready <= 1'b1;
	        end
	      else
	        begin
	          axi_wready <= 1'b0;
	        end
	    end
	end
	// Implement memory mapped register select and write logic generation
	// The write data is accepted and written to memory mapped registers when
	// axi_awready, S_AXI_WVALID, axi_wready and S_AXI_WVALID are asserted. Write strobes are used to
	// select byte enables of slave registers while writing.
	// These registers are cleared when reset (active low) is applied.
	// Slave register write enable is asserted when valid address and data are available
	// and the slave is ready to accept the write address and write data.
	assign slv_reg_wren = axi_wready && S_AXI_WVALID && axi_awready && S_AXI_AWVALID;
//	always @( posedge S_AXI_ACLK )
//	begin
//	  if ( S_AXI_ARESETN == 1'b0 )
//	    begin
//	    end
//	  else begin
//	    if (slv_reg_wren)
//	      begin
//	      end
//	  end
//	end
	// Implement write response logic generation
	// The write response and response valid signals are asserted by the slave
	// when axi_wready, S_AXI_WVALID, axi_wready and S_AXI_WVALID are asserted.
	// This marks the acceptance of address and indicates the status of
	// write transaction.
	begin
	    begin
	      axi_bvalid  <= 0;
	      axi_bresp   <= 2'b0;
	    end
	  else
	    begin
	      if (axi_awready && S_AXI_AWVALID && ~axi_bvalid && axi_wready && S_AXI_WVALID)
	        begin
	          // indicates a valid write response is available
	          axi_bvalid <= 1'b1;
	          axi_bresp  <= 2'b0; // 'OKAY' response
	        end                   // work error responses in future
	      else
	        begin
	            //check if bready is asserted while bvalid is high)
	            //(there is a possibility that bready is always asserted high)
	            begin
	              axi_bvalid <= 1'b0;
	            end
	        end
	    end
	end
	// Implement axi_arready generation
	// axi_arready is asserted for one S_AXI_ACLK clock cycle when
	// S_AXI_ARVALID is asserted. axi_awready is
	// de-asserted when reset (active low) is asserted.
	// The read address is also latched when S_AXI_ARVALID is
	// asserted. axi_araddr is reset to zero on reset assertion.
	begin
	    begin
	      axi_arready <= 1'b0;
	      axi_araddr  <= 32'b0;
	    end
	  else
	    begin
	      if (~axi_arready && S_AXI_ARVALID)
	        begin
	          // indicates that the slave has acceped the valid read address
	          axi_arready <= 1'b1;
	          // Read address latching
	          axi_araddr  <= S_AXI_ARADDR;
	        end
	      else
	        begin
	        end
	    end
	end
	// Implement axi_arvalid generation
	// axi_rvalid is asserted for one S_AXI_ACLK clock cycle when both
	// S_AXI_ARVALID and axi_arready are asserted. The slave registers
	// data are available on the axi_rdata bus at this instance. The
	// assertion of axi_rvalid marks the validity of read data on the
	// bus and axi_rresp indicates the status of read transaction.axi_rvalid
	// is deasserted on reset (active low). axi_rresp and axi_rdata are
	// cleared to zero on reset (active low).
	begin
	    begin
	      axi_rvalid <= 0;
	      axi_rresp  <= 0;
	    end
	  else
	    begin
	      if (axi_arready && S_AXI_ARVALID && ~axi_rvalid)
	        begin
	          // Valid read data is available at the read data bus
	          axi_rvalid <= 1'b1;
	          axi_rresp  <= 2'b0; // 'OKAY' response
	        end
	      else if (axi_rvalid && S_AXI_RREADY)
	        begin
	          // Read data is accepted by the master
	          axi_rvalid <= 1'b0;
	        end
	    end
	end
	// Implement memory mapped register select and read logic generation
	// Slave register read enable is asserted when valid address is available
	// and the slave is ready to accept the read address.
	assign slv_reg_rden = axi_arready & S_AXI_ARVALID & ~axi_rvalid;
	// Output register or memory read data
	begin
	    begin
	      axi_rdata  <= 0;
	    end
	  else
	    begin
	      // When there is a valid read address (S_AXI_ARVALID) with
	      // acceptance of read address by the slave (axi_arready),
	      // output the read dada
	      if (slv_reg_rden)
	        begin
//	          axi_rdata <= reg_data_out;     // register read data
	          axi_rdata <= preg_rdata;     // register read data
	        end
	    end
	end
assign preg_wren = slv_reg_wren;
assign preg_byte_en[3:0] = S_AXI_WSTRB[3:0];
assign preg_addr[USER_REG_ADDR_WIDTH-1:0] = axi_awaddr[ADDR_LSB+OPT_MEM_ADDR_BITS:ADDR_LSB];
assign preg_wdata[31:0] = S_AXI_WDATA[31:0];
assign preg_raddr[USER_REG_ADDR_WIDTH-1:0] = axi_araddr[ADDR_LSB+OPT_MEM_ADDR_BITS:ADDR_LSB];
	// User logic ends
	endmodule
Fullscreen pocket_interface_v1_0_S01_AXI.txt Download
	module pocket_interface_v1_0_S01_AXI #
		// Width of ID for for write address, write data, read address and read data
		parameter integer C_S_AXI_ID_WIDTH	= 1,
		parameter integer C_S_AXI_ADDR_WIDTH	= 14,
		// Width of optional user defined signal in write address channel
		parameter integer C_S_AXI_AWUSER_WIDTH	= 0,
		// Width of optional user defined signal in read address channel
		parameter integer C_S_AXI_ARUSER_WIDTH	= 0,
		// Width of optional user defined signal in write data channel
		parameter integer C_S_AXI_WUSER_WIDTH	= 0,
		// Width of optional user defined signal in read data channel
		parameter integer C_S_AXI_RUSER_WIDTH	= 0,
		// Width of optional user defined signal in write response channel
		parameter integer C_S_AXI_BUSER_WIDTH	= 0
		// User ports ends
		// Write Address ID
		input wire [C_S_AXI_ID_WIDTH-1 : 0] S_AXI_AWID,
		// Write address
		// Burst length. The burst length gives the exact number of transfers in a burst
		input wire [7 : 0] S_AXI_AWLEN,
		// Burst size. This signal indicates the size of each transfer in the burst
		input wire [2 : 0] S_AXI_AWSIZE,
		// Burst type. The burst type and the size information,
    // determine how the address for each transfer within the burst is calculated.
		input wire [1 : 0] S_AXI_AWBURST,
		// Lock type. Provides additional information about the
    // atomic characteristics of the transfer.
		input wire  S_AXI_AWLOCK,
		// Memory type. This signal indicates how transactions
    // are required to progress through a system.
		input wire [3 : 0] S_AXI_AWCACHE,
		// Quality of Service, QoS identifier sent for each
		input wire [3 : 0] S_AXI_AWQOS,
		// Region identifier. Permits a single physical interface
    // on a slave to be used for multiple logical interfaces.
		input wire [3 : 0] S_AXI_AWREGION,
		// Optional User-defined signal in the write address channel.
		input wire [C_S_AXI_AWUSER_WIDTH-1 : 0] S_AXI_AWUSER,
    // the channel is signaling valid write address and
    // control information.
    // the slave is ready to accept an address and associated
    // control signals.
		// Write Data
    // lanes hold valid data. There is one write strobe
    // bit for each eight bits of the write data bus.
		// Write last. This signal indicates the last transfer
    // in a write burst.
		input wire  S_AXI_WLAST,
		// Optional User-defined signal in the write data channel.
		input wire [C_S_AXI_WUSER_WIDTH-1 : 0] S_AXI_WUSER,
		// Response ID tag. This signal is the ID tag of the
    // write response.
		output wire [C_S_AXI_ID_WIDTH-1 : 0] S_AXI_BID,
		// Optional User-defined signal in the write response channel.
		output wire [C_S_AXI_BUSER_WIDTH-1 : 0] S_AXI_BUSER,
    // channel is signaling a valid write response.
		// Read address ID. This signal is the identification
    // tag for the read address group of signals.
		input wire [C_S_AXI_ID_WIDTH-1 : 0] S_AXI_ARID,
		// Read address. This signal indicates the initial
    // address of a read burst transaction.
		input wire [7 : 0] S_AXI_ARLEN,
		input wire [2 : 0] S_AXI_ARSIZE,
		input wire [1 : 0] S_AXI_ARBURST,
		input wire  S_AXI_ARLOCK,
		input wire [3 : 0] S_AXI_ARCACHE,
    // read transaction.
		input wire [3 : 0] S_AXI_ARQOS,
		input wire [3 : 0] S_AXI_ARREGION,
		// Optional User-defined signal in the read address channel.
		input wire [C_S_AXI_ARUSER_WIDTH-1 : 0] S_AXI_ARUSER,
    // the channel is signaling valid read address and
    // control signals.
		// Read ID tag. This signal is the identification tag
    // for the read data group of signals generated by the slave.
		output wire [C_S_AXI_ID_WIDTH-1 : 0] S_AXI_RID,
		// Read Data
    // the read transfer.
		// Read last. This signal indicates the last transfer
    // in a read burst.
		output wire  S_AXI_RLAST,
		output wire [C_S_AXI_RUSER_WIDTH-1 : 0] S_AXI_RUSER,
    // is signaling the required read data.
	// AXI4FULL signals
	reg  	axi_awready;
	reg  	axi_wready;
	reg [C_S_AXI_BUSER_WIDTH-1 : 0] 	axi_buser;
	reg  	axi_bvalid;
	reg  	axi_arready;
	reg  	axi_rlast;
	reg [C_S_AXI_RUSER_WIDTH-1 : 0] 	axi_ruser;
	reg  	axi_rvalid;
	// aw_wrap_en determines wrap boundary and enables wrapping
	wire aw_wrap_en;
	// ar_wrap_en determines wrap boundary and enables wrapping
	wire ar_wrap_en;
	// aw_wrap_size is the size of the write transfer, the
	// write address wraps to a lower address if upper address
	// limit is reached
	wire [31:0]  aw_wrap_size ;
	// ar_wrap_size is the size of the read transfer, the
	// read address wraps to a lower address if upper address
	// limit is reached
	wire [31:0]  ar_wrap_size ;
	// The axi_awv_awr_flag flag marks the presence of write address valid
	reg axi_awv_awr_flag;
	//The axi_arv_arr_flag flag marks the presence of read address valid
	reg axi_arv_arr_flag;
	// The axi_awlen_cntr internal write address counter to keep track of beats in a burst transaction
	reg [7:0] axi_awlen_cntr;
	//The axi_arlen_cntr internal read address counter to keep track of beats in a burst transaction
	reg [7:0] axi_arlen_cntr;
	reg [1:0] axi_arburst;
	reg [1:0] axi_awburst;
	reg [7:0] axi_arlen;
	reg [7:0] axi_awlen;
	//local parameter for addressing 32 bit / 64 bit C_S_AXI_DATA_WIDTH
	//ADDR_LSB is used for addressing 32/64 bit registers/memories
	//ADDR_LSB = 2 for 32 bits (n downto 2)
	//ADDR_LSB = 3 for 42 bits (n downto 3)
	localparam integer ADDR_LSB = (C_S_AXI_DATA_WIDTH/32)+ 1;
//	localparam integer OPT_MEM_ADDR_BITS = 8; // **** Address Space [8:0] Words
	localparam integer OPT_MEM_ADDR_BITS = USER_IRAM_ADDR_WIDTH-1;
	localparam integer USER_NUM_MEM = 1;
	//-- Signals for user logic memory space example
	wire [OPT_MEM_ADDR_BITS:0] mem_address;
	wire [USER_NUM_MEM-1:0] mem_select;
	reg [C_S_AXI_DATA_WIDTH-1:0] mem_data_out[0 : USER_NUM_MEM-1];
	genvar i;
	genvar j;
	genvar mem_byte_index;
	assign S_AXI_BUSER	= axi_buser;
	assign S_AXI_RLAST	= axi_rlast;
	assign S_AXI_RUSER	= axi_ruser;
	assign S_AXI_BID = S_AXI_AWID;
	assign S_AXI_RID = S_AXI_ARID;
	assign  aw_wrap_size = (C_S_AXI_DATA_WIDTH/8 * (axi_awlen));
	assign  ar_wrap_size = (C_S_AXI_DATA_WIDTH/8 * (axi_arlen));
	assign  aw_wrap_en = ((axi_awaddr & aw_wrap_size) == aw_wrap_size)? 1'b1: 1'b0;
	assign  ar_wrap_en = ((axi_araddr & ar_wrap_size) == ar_wrap_size)? 1'b1: 1'b0;
	begin
	    begin
	      axi_awv_awr_flag <= 1'b0;
	    end
	  else
	    begin
	      if (~axi_awready && S_AXI_AWVALID && ~axi_awv_awr_flag && ~axi_arv_arr_flag)
	        begin
	          // slave is ready to accept an address and
	          // associated control signals
	          axi_awv_awr_flag  <= 1'b1;
	          // used for generation of bresp() and bvalid
	        end
	      else if (S_AXI_WLAST && axi_wready)
	      // preparing to accept next address after current write burst tx completion
	        begin
	        end
	      else
	        begin
	        end
	    end
	end
	begin
	    begin
	      axi_awaddr <= 0;
	      axi_awlen_cntr <= 0;
	      axi_awburst <= 0;
	      axi_awlen <= 0;
	    end
	  else
	    begin
	      if (~axi_awready && S_AXI_AWVALID && ~axi_awv_awr_flag)
	        begin
	          // address latching
	          axi_awaddr <= S_AXI_AWADDR[C_S_AXI_ADDR_WIDTH - 1:0];
	           axi_awburst <= S_AXI_AWBURST;
	           axi_awlen <= S_AXI_AWLEN;
	          // start address of transfer
	        end
	      else if((axi_awlen_cntr <= axi_awlen) && axi_wready && S_AXI_WVALID)
	        begin
	          axi_awlen_cntr <= axi_awlen_cntr + 1;
	          case (axi_awburst)
	            2'b00: // fixed burst
	            // The write address for all the beats in the transaction are fixed
	              begin
	                axi_awaddr <= axi_awaddr;
	                //for awsize = 4 bytes (010)
	              end
	            2'b01: //incremental burst
	            // The write address for all the beats in the transaction are increments by awsize
	              begin
	                axi_awaddr[C_S_AXI_ADDR_WIDTH - 1:ADDR_LSB] <= axi_awaddr[C_S_AXI_ADDR_WIDTH - 1:ADDR_LSB] + 1;
	                //awaddr aligned to 4 byte boundary
	                axi_awaddr[ADDR_LSB-1:0]  <= {ADDR_LSB{1'b0}};
	              end
	            2'b10: //Wrapping burst
	            // The write address wraps when the address reaches wrap boundary
	              if (aw_wrap_en)
	                begin
	                  axi_awaddr <= (axi_awaddr - aw_wrap_size);
	                end
	              else
	                begin
	                end
	            default: //reserved (incremental burst for example)
	              begin
	                axi_awaddr <= axi_awaddr[C_S_AXI_ADDR_WIDTH - 1:ADDR_LSB] + 1;
	              end
	          endcase
	        end
	    end
	end
	begin
	    begin
	      axi_wready <= 1'b0;
	    end
	  else
	    begin
	      if ( ~axi_wready && S_AXI_WVALID && axi_awv_awr_flag)
	        begin
	          // slave can accept the write data
	          axi_wready <= 1'b1;
	        end
	      //else if (~axi_awv_awr_flag)
	        begin
	          axi_wready <= 1'b0;
	        end
	    end
	end
	begin
	    begin
	      axi_bvalid <= 0;
	      axi_bresp <= 2'b0;
	      axi_buser <= 0;
	    end
	  else
	    begin
	      if (axi_awv_awr_flag && axi_wready && S_AXI_WVALID && ~axi_bvalid && S_AXI_WLAST )
	        begin
	          axi_bvalid <= 1'b1;
	          axi_bresp  <= 2'b0;
	          // 'OKAY' response
	        end
	      else
	        begin
	            begin
	              axi_bvalid <= 1'b0;
	            end
	        end
	    end
	 end
	begin
	    begin
	      axi_arv_arr_flag <= 1'b0;
	    end
	  else
	    begin
	      if (~axi_arready && S_AXI_ARVALID && ~axi_awv_awr_flag && ~axi_arv_arr_flag)
	        begin
	          axi_arv_arr_flag <= 1'b1;
	        end
	      else if (axi_rvalid && S_AXI_RREADY && axi_arlen_cntr == axi_arlen)
	      // preparing to accept next address after current read completion
	        begin
	        end
	      else
	        begin
	        end
	    end
	end
	// Implement axi_araddr latching
	//This process is used to latch the address when both
	//S_AXI_ARVALID and S_AXI_RVALID are valid.
	begin
	    begin
	      axi_araddr <= 0;
	      axi_arlen_cntr <= 0;
	      axi_arburst <= 0;
	      axi_arlen <= 0;
	      axi_rlast <= 1'b0;
	      axi_ruser <= 0;
	    end
	  else
	    begin
	      if (~axi_arready && S_AXI_ARVALID && ~axi_arv_arr_flag)
	        begin
	          // address latching
	          axi_araddr <= S_AXI_ARADDR[C_S_AXI_ADDR_WIDTH - 1:0];
	          axi_arburst <= S_AXI_ARBURST;
	          axi_arlen <= S_AXI_ARLEN;
	          axi_rlast <= 1'b0;
	        end
	      else if((axi_arlen_cntr <= axi_arlen) && axi_rvalid && S_AXI_RREADY)
	        begin
	          axi_arlen_cntr <= axi_arlen_cntr + 1;
	          axi_rlast <= 1'b0;
	          case (axi_arburst)
	             // The read address for all the beats in the transaction are fixed
	              begin
	                axi_araddr       <= axi_araddr;
	                //for arsize = 4 bytes (010)
	              end
	            // The read address for all the beats in the transaction are increments by awsize
	              begin
	                axi_araddr[C_S_AXI_ADDR_WIDTH - 1:ADDR_LSB] <= axi_araddr[C_S_AXI_ADDR_WIDTH - 1:ADDR_LSB] + 1;
	                //araddr aligned to 4 byte boundary
	                axi_araddr[ADDR_LSB-1:0]  <= {ADDR_LSB{1'b0}};
	              end
	            // The read address wraps when the address reaches wrap boundary
	              if (ar_wrap_en)
	                begin
	                  axi_araddr <= (axi_araddr - ar_wrap_size);
	                end
	              else
	                begin
	                end
	              begin
	                axi_araddr <= axi_araddr[C_S_AXI_ADDR_WIDTH - 1:ADDR_LSB]+1;
	              end
	          endcase
	        end
	      else if((axi_arlen_cntr == axi_arlen) && ~axi_rlast && axi_arv_arr_flag )
	        begin
	          axi_rlast <= 1'b1;
	        end
	      else if (S_AXI_RREADY)
	        begin
	          axi_rlast <= 1'b0;
	        end
	    end
	end
	begin
	    begin
	      axi_rvalid <= 0;
	      axi_rresp  <= 0;
	    end
	  else
	    begin
	      if (axi_arv_arr_flag && ~axi_rvalid)
	        begin
	          axi_rvalid <= 1'b1;
	          axi_rresp  <= 2'b0;
	          // 'OKAY' response
	        end
	        begin
	          axi_rvalid <= 1'b0;
	        end
	    end
	end
	// -- Example code to access user logic memory region
//	generate
//	  if (USER_NUM_MEM >= 1)
//	    begin
//	      assign mem_select  = 1;
//	      assign mem_address = (axi_arv_arr_flag? axi_araddr[ADDR_LSB+OPT_MEM_ADDR_BITS:ADDR_LSB]:(axi_awv_awr_flag? axi_awaddr[ADDR_LSB+OPT_MEM_ADDR_BITS:ADDR_LSB]:0));
//	    end
//	endgenerate
	// implement Block RAM(s)
//	generate
//	  for(i=0; i<= USER_NUM_MEM-1; i=i+1)
//	    begin:BRAM_GEN
//	      wire mem_rden;
//	      wire mem_wren;
//	      assign mem_wren = axi_wready && S_AXI_WVALID ;
//	      assign mem_rden = axi_arv_arr_flag ; //& ~axi_rvalid
//	      for(mem_byte_index=0; mem_byte_index<= (C_S_AXI_DATA_WIDTH/8-1); mem_byte_index=mem_byte_index+1)
//	      begin:BYTE_BRAM_GEN
//	        wire [8-1:0] data_in ;
//	        wire [8-1:0] data_out;
//	        reg  [8-1:0] byte_ram [0 : 255];
//	        integer  j;
	        //assigning 8 bit data
//	        assign data_in  = S_AXI_WDATA[(mem_byte_index*8+7) -: 8];
//	        assign data_out = byte_ram[mem_address];
//	        begin
//	          if (mem_wren && S_AXI_WSTRB[mem_byte_index])
//	            begin
//	              byte_ram[mem_address] <= data_in;
//	            end
//	        end
//	        begin
//	          if (mem_rden)
//	            begin
//	              mem_data_out[i][(mem_byte_index*8+7) -: 8] <= data_out;
//	            end
//	        end
//	    end
//	  end
//	endgenerate
	//Output register or memory read data
//	always @( mem_data_out, axi_rvalid)
//	begin
//	  if (axi_rvalid)
//	    begin
	      // Read address mux
//	      axi_rdata <= mem_data_out[0];
//	    end
//	  else
//	    begin
//	      axi_rdata <= 32'h00000000;
//	    end
//	end
//wire tdp_clk_a   = S_AXI_ACLK;
//wire tdp_reset_a = ~S_AXI_ARESETN;
// Read and Write Enables
wire tdp_wren = axi_wready && S_AXI_WVALID ;
wire tdp_rden = axi_arv_arr_flag ; //& ~axi_rvalid
// Enable A or read or write
assign        tdp_en_a      = tdp_wren || tdp_rden;
assign   tdp_wren_a[3:0]   = {4{tdp_wren}} & S_AXI_WSTRB[3:0]; // Write Enables
//wire [7:0] tdp_low_addr = (axi_arv_arr_flag? axi_araddr[ADDR_LSB+OPT_MEM_ADDR_BITS:ADDR_LSB]:(axi_awv_awr_flag? axi_awaddr[ADDR_LSB+OPT_MEM_ADDR_BITS:ADDR_LSB]:0));
//wire [9:0] tdp_addr_a   = {2'b00, tdp_low_addr[7:0]};
//wire  [8:0] tdp_low_addr = (axi_arv_arr_flag? axi_araddr[ADDR_LSB+OPT_MEM_ADDR_BITS:ADDR_LSB]:(axi_awv_awr_flag? axi_awaddr[ADDR_LSB+OPT_MEM_ADDR_BITS:ADDR_LSB]:0));
//assign   tdp_addr_a[9:0]   = {1'b0, tdp_low_addr[8:0]};
assign   tdp_addr_a =  (axi_arv_arr_flag? axi_araddr[ADDR_LSB+OPT_MEM_ADDR_BITS:ADDR_LSB]:(axi_awv_awr_flag? axi_awaddr[ADDR_LSB+OPT_MEM_ADDR_BITS:ADDR_LSB]:0));
//wire [35:0] tdp_din_a    = {4'b0000, S_AXI_WDATA[31:0]};
assign  tdp_din_a[31:0]    = S_AXI_WDATA[31:0];
// wire [35:0] tdp_dout_a;
	always @( tdp_dout_a, axi_rvalid)
	begin
	  if (axi_rvalid)
	    begin
	      // Read address mux
	      axi_rdata <= tdp_dout_a[31:0];
	    end
	  else
	    begin
	    end
	end
	// User logic ends
	endmodule
Fullscreen proto_core_top_regs_ex.txt Download
// Registers for proto_core_top
module proto_core_top_regs #(
parameter FRAC     = 19, // Fractional bits
parameter CHANNELS = 50  // Number of channels
  input                         clk2pow25,          // System clock 2^25 MHz
  input                         reset_clk2pow25,    // Active high sync reset
  input wire clk_axi,    // Clock for AXI4 domain
  input wire resetn_axi, // Active low sync reset
  // A2D SPI Interface
  output wire            ad_sclk,      // A2D SPI Clock
  output wire            ad_csb,       // A2D SPI Enable SPI-Active Low
  inout  wire            ad_sdio,      // A2D SPI Serial I/O Data
  input  wire        preg_wren,    // Register Write Enable
  input  wire  [3:0] preg_byte_en, // Register Byte Write Enables
  input  wire  [9:0] preg_addr,    // Register Write Address
  input  wire [31:0] preg_wdata,   // Register Write data
  input  wire  [9:0] preg_raddr,   // Register Read Address
  output reg  [31:0] preg_rdata    // Register Read data
localparam integer C_S_AXI_DATA_WIDTH	= 32;
integer  byte_index;
//-- Number of Slave Registers 16
// Toggle Registers
reg slv_reg0_tog;
reg slv_reg1_tog;
reg slv_reg2_tog;
reg slv_reg3_tog;
reg slv_reg4_tog;
reg slv_reg5_tog;
reg slv_reg6_tog;
reg slv_reg7_tog;
reg slv_reg8_tog;
reg slv_reg9_tog;
reg slv_reg10_tog;
reg slv_reg11_tog;
reg slv_reg12_tog;
reg slv_reg13_tog;
reg slv_reg14_tog;
reg slv_reg15_tog;
reg slv_reg16_tog;
reg slv_reg17_tog;
reg slv_reg18_tog;
reg slv_reg19_tog;
reg slv_reg20_tog;
reg slv_reg21_tog;
reg slv_reg22_tog;
reg slv_reg23_tog;
reg slv_reg24_tog;
reg slv_reg25_tog;
reg slv_reg26_tog;
reg slv_reg27_tog;
reg slv_reg28_tog;
reg slv_reg29_tog;
reg slv_reg30_tog;
reg slv_reg31_tog;
reg [C_S_AXI_DATA_WIDTH-1:0] slv_reg0;
reg [C_S_AXI_DATA_WIDTH-1:0] slv_reg1;
reg [C_S_AXI_DATA_WIDTH-1:0] slv_reg2;
reg [C_S_AXI_DATA_WIDTH-1:0] slv_reg3;
reg [C_S_AXI_DATA_WIDTH-1:0] slv_reg4;
reg [C_S_AXI_DATA_WIDTH-1:0] slv_reg5;
reg [C_S_AXI_DATA_WIDTH-1:0] slv_reg6;
reg [C_S_AXI_DATA_WIDTH-1:0] slv_reg7;
reg [C_S_AXI_DATA_WIDTH-1:0] slv_reg8;
reg [C_S_AXI_DATA_WIDTH-1:0] slv_reg9;
reg [C_S_AXI_DATA_WIDTH-1:0] slv_reg10;
reg [C_S_AXI_DATA_WIDTH-1:0] slv_reg11;
reg [C_S_AXI_DATA_WIDTH-1:0] slv_reg12;
reg [C_S_AXI_DATA_WIDTH-1:0] slv_reg13;
reg [C_S_AXI_DATA_WIDTH-1:0] slv_reg14;
reg [C_S_AXI_DATA_WIDTH-1:0] slv_reg15;
reg [C_S_AXI_DATA_WIDTH-1:0] slv_reg16;
reg [C_S_AXI_DATA_WIDTH-1:0] slv_reg17;
reg [C_S_AXI_DATA_WIDTH-1:0] slv_reg18;
reg [C_S_AXI_DATA_WIDTH-1:0] slv_reg19;
reg [C_S_AXI_DATA_WIDTH-1:0] slv_reg20;
reg [C_S_AXI_DATA_WIDTH-1:0] slv_reg21;
reg [C_S_AXI_DATA_WIDTH-1:0] slv_reg22;
reg [C_S_AXI_DATA_WIDTH-1:0] slv_reg23;
reg [C_S_AXI_DATA_WIDTH-1:0] slv_reg24;
reg [C_S_AXI_DATA_WIDTH-1:0] slv_reg25;
reg [C_S_AXI_DATA_WIDTH-1:0] slv_reg26;
reg [C_S_AXI_DATA_WIDTH-1:0] slv_reg27;
reg [C_S_AXI_DATA_WIDTH-1:0] slv_reg28;
reg [C_S_AXI_DATA_WIDTH-1:0] slv_reg29;
reg [C_S_AXI_DATA_WIDTH-1:0] slv_reg30;
reg [C_S_AXI_DATA_WIDTH-1:0] slv_reg31;
always @( posedge clk_axi )
  begin
  if ( resetn_axi == 1'b0 )
    begin
    slv_reg0_tog <= 0;
    slv_reg1_tog <= 0;
    slv_reg2_tog <= 0;
    slv_reg3_tog <= 0;
    slv_reg4_tog <= 0;
    slv_reg5_tog <= 0;
    slv_reg6_tog <= 0;
    slv_reg7_tog <= 0;
    slv_reg8_tog <= 0;
    slv_reg9_tog <= 0;
    slv_reg10_tog <= 0;
    slv_reg11_tog <= 0;
    slv_reg12_tog <= 0;
    slv_reg13_tog <= 0;
    slv_reg14_tog <= 0;
    slv_reg15_tog <= 0;
    slv_reg16_tog <= 0;
    slv_reg17_tog <= 0;
    slv_reg18_tog <= 0;
    slv_reg19_tog <= 0;
    slv_reg20_tog <= 0;
    slv_reg21_tog <= 0;
    slv_reg22_tog <= 0;
    slv_reg23_tog <= 0;
    slv_reg24_tog <= 0;
    slv_reg25_tog <= 0;
    slv_reg26_tog <= 0;
    slv_reg27_tog <= 0;
    slv_reg28_tog <= 0;
    slv_reg29_tog <= 0;
    slv_reg30_tog <= 0;
    slv_reg31_tog <= 0;
    slv_reg0 <= 0;
    slv_reg1 <= 0;
    slv_reg2 <= 0;
    slv_reg3 <= 0;
    slv_reg4 <= 0;
    slv_reg5 <= 0;
    slv_reg6 <= 0;
    slv_reg7 <= 0;
    slv_reg8 <= 0;
    slv_reg9 <= 0;
    slv_reg10 <= 0;
    slv_reg11 <= 0;
    slv_reg12 <= 32'h00000006;
    slv_reg13 <= 0;
    slv_reg14 <= 0;
    slv_reg15 <= 0;
    slv_reg16 <= 0;
    slv_reg17 <= 0;
    slv_reg18 <= 0;
    slv_reg19 <= 0;
    slv_reg20 <= 0;
    slv_reg21 <= 0;
    slv_reg22 <= 0;
    slv_reg23 <= 0;
    slv_reg24 <= 0;
    slv_reg25 <= 0;
    slv_reg26 <= 0;
    slv_reg27 <= 0;
    slv_reg28 <= 0;
    slv_reg29 <= 0;
    slv_reg30 <= 0;
    slv_reg31 <= 0;
    end
  else
    begin
    if (preg_wren)
      begin
      case ( preg_addr[4:0] )
      5'h00:
        begin
        if (|preg_byte_en[3:0]) // Any byte write enables then toggle
          slv_reg0_tog <= ~slv_reg0_tog;
        for ( byte_index = 0; byte_index <= (C_S_AXI_DATA_WIDTH/8)-1; byte_index = byte_index+1 )
          if ( preg_byte_en[byte_index] == 1 )
            begin
            // Respective byte enables are asserted as per write strobes
            // Slave register 0
            slv_reg0[(byte_index*8) +: 8] <= preg_wdata[(byte_index*8) +: 8];
            end
        end // case: 5'h00
      5'h01:
        begin
          slv_reg1_tog <= ~slv_reg1_tog;
            begin
            // Slave register 1
            slv_reg1[(byte_index*8) +: 8] <= preg_wdata[(byte_index*8) +: 8];
            end
        end
      5'h02:
        begin
          slv_reg2_tog <= ~slv_reg2_tog;
            begin
            // Slave register 2
            slv_reg2[(byte_index*8) +: 8] <= preg_wdata[(byte_index*8) +: 8];
            end
        end
      5'h03:
        begin
          slv_reg3_tog <= ~slv_reg3_tog;
            begin
            // Slave register 3
            slv_reg3[(byte_index*8) +: 8] <= preg_wdata[(byte_index*8) +: 8];
            end
        end
      5'h04:
        begin
          slv_reg4_tog <= ~slv_reg4_tog;
            begin
            // Slave register 4
            slv_reg4[(byte_index*8) +: 8] <= preg_wdata[(byte_index*8) +: 8];
            end
        end
      5'h05:
        begin
          slv_reg5_tog <= ~slv_reg5_tog;
            begin
            // Slave register 5
            slv_reg5[(byte_index*8) +: 8] <= preg_wdata[(byte_index*8) +: 8];
            end
        end
      5'h06:
        begin
          slv_reg6_tog <= ~slv_reg6_tog;
            begin
            // Slave register 6
            slv_reg6[(byte_index*8) +: 8] <= preg_wdata[(byte_index*8) +: 8];
            end
        end
      5'h07:
        begin
          slv_reg7_tog <= ~slv_reg7_tog;
            begin
            // Slave register 7
            slv_reg7[(byte_index*8) +: 8] <= preg_wdata[(byte_index*8) +: 8];
            end
        end
      5'h08:
        begin
          slv_reg8_tog <= ~slv_reg8_tog;
            begin
            // Slave register 8
            slv_reg8[(byte_index*8) +: 8] <= preg_wdata[(byte_index*8) +: 8];
            end
        end
      5'h09:
        begin
          slv_reg9_tog <= ~slv_reg9_tog;
            begin
            // Slave register 9
            slv_reg9[(byte_index*8) +: 8] <= preg_wdata[(byte_index*8) +: 8];
            end
        end
      5'h0A:
        begin
          slv_reg10_tog <= ~slv_reg10_tog;
            begin
            // Slave register 10
            slv_reg10[(byte_index*8) +: 8] <= preg_wdata[(byte_index*8) +: 8];
            end
        end
      5'h0B:
        begin
          slv_reg11_tog <= ~slv_reg11_tog;
            begin
            // Slave register 11
            slv_reg11[(byte_index*8) +: 8] <= preg_wdata[(byte_index*8) +: 8];
            end
        end
      5'h0C:
        begin
          slv_reg12_tog <= ~slv_reg12_tog;
            begin
            // Slave register 12
            slv_reg12[(byte_index*8) +: 8] <= preg_wdata[(byte_index*8) +: 8];
            end
        end
      5'h0D:
        begin
          slv_reg13_tog <= ~slv_reg13_tog;
            begin
            // Slave register 13
            slv_reg13[(byte_index*8) +: 8] <= preg_wdata[(byte_index*8) +: 8];
            end
        end
      5'h0E:
        begin
          slv_reg14_tog <= ~slv_reg14_tog;
            begin
            // Slave register 14
            slv_reg14[(byte_index*8) +: 8] <= preg_wdata[(byte_index*8) +: 8];
            end
        end
      5'h0F:
        begin
          slv_reg15_tog <= ~slv_reg15_tog;
            begin
            // Slave register 15
            slv_reg15[(byte_index*8) +: 8] <= preg_wdata[(byte_index*8) +: 8];
            end
        end
      5'h10:
        begin
          slv_reg16_tog <= ~slv_reg16_tog;
            begin
            // Slave register 16
            slv_reg16[(byte_index*8) +: 8] <= preg_wdata[(byte_index*8) +: 8];
            end
        end
      5'h11:
        begin
          slv_reg17_tog <= ~slv_reg17_tog;
            begin
            // Slave register 17
            slv_reg17[(byte_index*8) +: 8] <= preg_wdata[(byte_index*8) +: 8];
            end
        end
      5'h12:
        begin
          slv_reg18_tog <= ~slv_reg18_tog;
            begin
            // Slave register 18
            slv_reg18[(byte_index*8) +: 8] <= preg_wdata[(byte_index*8) +: 8];
            end
        end
     5'h13:
        begin
          slv_reg19_tog <= ~slv_reg19_tog;
            begin
            // Slave register 19
            slv_reg19[(byte_index*8) +: 8] <= preg_wdata[(byte_index*8) +: 8];
            end
        end
      5'h14:
        begin
          slv_reg20_tog <= ~slv_reg20_tog;
            begin
            // Slave register 20
            slv_reg20[(byte_index*8) +: 8] <= preg_wdata[(byte_index*8) +: 8];
            end
        end
      5'h15:
        begin
          slv_reg21_tog <= ~slv_reg21_tog;
            begin
            // Slave register 21
            slv_reg21[(byte_index*8) +: 8] <= preg_wdata[(byte_index*8) +: 8];
            end
        end
      5'h16:
        begin
          slv_reg22_tog <= ~slv_reg22_tog;
            begin
            // Slave register 22
            slv_reg22[(byte_index*8) +: 8] <= preg_wdata[(byte_index*8) +: 8];
            end
        end
      5'h17:
        begin
          slv_reg23_tog <= ~slv_reg23_tog;
            begin
            // Slave register 23
            slv_reg23[(byte_index*8) +: 8] <= preg_wdata[(byte_index*8) +: 8];
            end
        end
      5'h18:
        begin
          slv_reg24_tog <= ~slv_reg24_tog;
            begin
            // Slave register 24
            slv_reg24[(byte_index*8) +: 8] <= preg_wdata[(byte_index*8) +: 8];
            end
        end
      5'h19:
        begin
          slv_reg25_tog <= ~slv_reg25_tog;
            begin
            // Slave register 25
            slv_reg25[(byte_index*8) +: 8] <= preg_wdata[(byte_index*8) +: 8];
            end
        end
      5'h1A:
        begin
          slv_reg26_tog <= ~slv_reg26_tog;
            begin
            // Slave register 26
            slv_reg26[(byte_index*8) +: 8] <= preg_wdata[(byte_index*8) +: 8];
            end
        end
      5'h1B:
        begin
          slv_reg27_tog <= ~slv_reg27_tog;
            begin
            // Slave register 27
            slv_reg27[(byte_index*8) +: 8] <= preg_wdata[(byte_index*8) +: 8];
            end
        end
      5'h1C:
        begin
          slv_reg28_tog <= ~slv_reg28_tog;
          begin
          // Slave register 28
          slv_reg28[(byte_index*8) +: 8] <= preg_wdata[(byte_index*8) +: 8];
          end
        end
      5'h1D:
        begin
          slv_reg29_tog <= ~slv_reg29_tog;
            begin
            // Slave register 29
            slv_reg29[(byte_index*8) +: 8] <= preg_wdata[(byte_index*8) +: 8];
            end
        end
      5'h1E:
        begin
          slv_reg30_tog <= ~slv_reg30_tog;
            begin
            // Slave register 30
            slv_reg30[(byte_index*8) +: 8] <= preg_wdata[(byte_index*8) +: 8];
            end
        end
      5'h1F:
        begin
          slv_reg31_tog <= ~slv_reg31_tog;
            begin
            // Slave register 31
            slv_reg31[(byte_index*8) +: 8] <= preg_wdata[(byte_index*8) +: 8];
            end
        end
      default : // From example code but isn't needed
        begin
        slv_reg0 <= slv_reg0;
        slv_reg1 <= slv_reg1;
        slv_reg2 <= slv_reg2;
        slv_reg3 <= slv_reg3;
        slv_reg4 <= slv_reg4;
        slv_reg5 <= slv_reg5;
        slv_reg6 <= slv_reg6;
        slv_reg7 <= slv_reg7;
        slv_reg8 <= slv_reg8;
        slv_reg9 <= slv_reg9;
        slv_reg10 <= slv_reg10;
        slv_reg11 <= slv_reg11;
        slv_reg12 <= slv_reg12;
        slv_reg13 <= slv_reg13;
        slv_reg14 <= slv_reg14;
        slv_reg15 <= slv_reg15;
        slv_reg16 <= slv_reg16;
        slv_reg17 <= slv_reg17;
        slv_reg18 <= slv_reg18;
        slv_reg19 <= slv_reg19;
        slv_reg20 <= slv_reg20;
        slv_reg21 <= slv_reg21;
        slv_reg22 <= slv_reg22;
        slv_reg23 <= slv_reg23;
        slv_reg24 <= slv_reg24;
        slv_reg25 <= slv_reg25;
        slv_reg26 <= slv_reg26;
        slv_reg27 <= slv_reg27;
        slv_reg28 <= slv_reg28;
        slv_reg29 <= slv_reg29;
        slv_reg30 <= slv_reg30;
        slv_reg31 <= slv_reg31;
        end // case: default
      endcase // case ( preg_addr[4:0] )
      end // if (preg_wren)
    end // else: !if( resetn_axi == 1'b0 )
  end // always @ ( posedge clk_axi )
assign ad_sclk = slv_reg12[2];
assign ad_csb  = slv_reg12[1];
assign ad_sdio = slv_reg12[0];
// Combinatorial select
always @(*)
  begin
  // Address decoding for reading registers
  case ( preg_raddr[4:0] )
  5'h00   : preg_rdata <= slv_reg0;
  5'h01   : preg_rdata <= slv_reg1;
  5'h02   : preg_rdata <= slv_reg2;
  5'h03   : preg_rdata <= slv_reg3;
  5'h04   : preg_rdata <= slv_reg4;
  5'h05   : preg_rdata <= slv_reg5;
  5'h06   : preg_rdata <= slv_reg6;
  5'h07   : preg_rdata <= slv_reg7;
  5'h08   : preg_rdata <= slv_reg8;
  5'h09   : preg_rdata <= slv_reg9;
  5'h0A   : preg_rdata <= slv_reg10;
  5'h0B   : preg_rdata <= slv_reg11;
  5'h0C   : preg_rdata <= slv_reg12;
  5'h0D   : preg_rdata <= slv_reg13;
  5'h0E   : preg_rdata <= slv_reg14;
  5'h0F   : preg_rdata <= slv_reg15;
  5'h10   : preg_rdata <= slv_reg16;
  5'h11   : preg_rdata <= slv_reg17;
  5'h12   : preg_rdata <= slv_reg18;
  5'h13   : preg_rdata <= slv_reg19;
  5'h14   : preg_rdata <= slv_reg20;
  5'h15   : preg_rdata <= slv_reg21;
  5'h16   : preg_rdata <= slv_reg22;
  5'h17   : preg_rdata <= slv_reg23;
  5'h18   : preg_rdata <= slv_reg24;
  5'h19   : preg_rdata <= slv_reg25;
  5'h1A   : preg_rdata <= slv_reg26;
  5'h1B   : preg_rdata <= slv_reg27;
  5'h1C   : preg_rdata <= slv_reg28;
  5'h1D   : preg_rdata <= slv_reg29;
  5'h1E   : preg_rdata <= slv_reg30;
  5'h1F   : preg_rdata <= slv_reg31;
  default : preg_rdata <= 0;
  endcase
  end // always @ (*)
endmodule // proto_core_top_regs
  • dniemann17
    dniemann17 over 2 years ago +2 suggested
    Update: we fixed the issue by re-writing the RTL module. Seems as if some files handed off to me didn't want to cooperate with each other and re-writing solved the issue.
  • dyessgg
    0 dyessgg over 2 years ago
    Have you instantiated and run the AXI protocol verification block in your design or at the very least marked the interface for debug so you can run the ILA?
    That would help you spot any AXI violations.  Don't just guess.  Observe and measure using tools Xilinx gives you.
  • dniemann17
    0 dniemann17 over 2 years ago in reply to dyessgg
    I mentioned in my post that the verification block documentation was outdated and we weren't able to follow.
    I would love if you could link me an up to date version of the AXI protocol verification block for Vivado 2023.2, since all I found for instructions is AXI Basics 2 - Simulating AXI interfaces with the AXI Verification IP (AXI VIP) (xilinx.com)
  • dyessgg
    0 dyessgg over 2 years ago in reply to dniemann17
    Two simple ways, pick the one you like the best.
    1. Mark the AXI interface as Debug by right clicking on the connection and select "Mark as Debug".  That will add all the necessary components.
    2. Click the "+" to add an IP block.  Search for "Integrated Logic Analyzer" and add that to your block diagram.  Then customize the block by adding at least one AXI interface.  Connect that to your AXI interface you want to debug.
    Another oldie but goodie is RTFM!  There won't be a ready-made example of every little thing you want to do in your engineering life.  Sometimes it will take reading the manuals.  Start with ILA and search the Xilinx Documentation (I refuse to call it AMD since AMD didn't create any of this technology) and go through the Design Hubs.  If you want to be an engineer, you're going to have to just some work on your own.
    • Vote Up -1 Vote Down
  • dniemann17
    Neither of those options answer my original question, nor do we want to use an ILA or create a whole debug net for the AXI bus.
    We would like to solve this issue using simulation or an AXI Passthrough Test Bus and simply telling me to RTFM doesn't solve the issue when we don't want to use an ILA, nor a debug net.
  • dyessgg
    Good luck in solving your problem when you refuse to use the debugging tools provided.
  • dniemann17
    Those are way overcomplicated for us and give us way too much information to sift through 99% of which we probably don't need.
    It seems that you assume this is a smaller project that we can use the ILA for, that is simply not the case, this project is massive and using an ILA and debug nets is a valid, but rougher way of solving smaller issues in a massive project. Those debugging tools aren't for every problem in Vivado.
  • dniemann17
