ZUBoard Synthesis Failing for Zuboard Project Vivado 2022.2
  • Subscribers 362 subscribers
  • Views 405 views
npv-qci
npv-qci over 2 years ago
I am trying to just build the zuboard vivado project on the 2022.2 branch of the avnet git repo. during synthesis, I get the following error:
##### ERROR: Synthesis synth_1 failed!
    while executing
"error "##### ERROR: Synthesis synth_1 failed!""
    invoked from within
"if {[get_property PROGRESS [get_runs synth_1]] != "100%"} {
      puts ""
    invoked from within
"if {[string match -nocase "yes" $clean]} {
   # Clean up project output products.
   # Open the existing project.
   puts ""
   puts "***** Opening V..."
    (file "./project_scripts/zub1cg_sbc_base.tcl" line 48)
    while executing
"source ./project_scripts/${board}_${project}.tcl -notrace "
    ("zub1cg_sbc" arm line 2)
    invoked from within
"switch -nocase $board {
   pz7010_fmc2                -
   pz7020_fmc2                -
   pz7015_fmc2                -
   pz7030_fmc2                ..."
    (file "./make.tcl" line 385)
    while executing
"source ./make.tcl -notrace"
    invoked from within
"if {$argc != 0} {
	# Build base hw platform
	set argv [list board=[lindex $argv 0] project=[lindex $argv 1] sdk=no close_project=yes dev_arch=zynqmp]
    (file "./make_zub1cg_sbc_base.tcl" line 44)
INFO: [Common 17-206] Exiting Vivado at Fri Dec  1 12:14:53 2023...
Any help tracking down the issue is appreciated. I also get the same error when I attempt to make the bsp with petalinux, as it also calls vivado to run synthesis.
