ZUBoard BSP for ZUBoard 1CG Board
  • Subscribers 362 subscribers
  • Views 2143 views
  • avnet
  • petalinux
  • xilinx zynq® ultrascale+ mpsoc
  • bsp
  • ZUBoard
Navin_08
Navin_08 over 2 years ago
Hi all,
Can you please provide ZUBoard 1CG BSP supporting the petalinux .I need the BSP to build an image and bringup my boart using the BSP. I have already explored the FreeRTOS. Now I am searching for the BSP in Petalinux Website here I am not able to find ZUBoard 1CG releated BSP. so can you please help me by finding the correct BSP .
Thanks & Regards
Navin
  • lightcollector
    lightcollector over 2 years ago
    Hi Navin,  There are several options for the ZUboard 1CG.
    There is a PYNQ OS image that makes the ZUBoard behave a lot like a Raspberry PI from a software perspective.  You basically have to download the image and use Balena Etcher to image it onto a micro SD card.  You can find that image here:  PYNQ - Python productivity for Zynq - Board
    I am not the author but there is a post here about how to build your own bsp.  This requires a fair amount of tool knowledge and setup to fully understand what is going on, but the steps are easy to follow:  Getting Started with Avnet's ZUBoard-1CG - Hackster.io
    Here is a link to a 2022.2 petalinux image for the ZU Board, there should have been a link in the quick start guide?  Look under the BSP folder for the one for the ZUBoard:
    Engineering & Technology - Documentation - 2022.2 - All Documents (sharepoint.com)
    Have a great day!
  • padudle
    padudle over 2 years ago
    It is really optional to use a Petalinux BSP.  I prefer to start from a compiled fpga design and extract the needed information from the xsa file.  The command looks like this.
    petalinux-config --get-hw-description=../../implement/results/
    The results folder contains the .xsa file created by the fpga compile script.  If you want to see the whole flow you could look at
    https://github.com/hdlguy/zuboard/blob/main/petalinux/readme.md
  • dano056
    dano056 over 2 years ago in reply to lightcollector
    Hi there, the petalinux image doesn't seem to work for me. I looks like you must be a member of the avnet sharepoint org? Is this correct?
