ZUBoard ZuBoard 1CG + AES-ACC-DPEMMC-G, no display
  • Subscribers 363 subscribers
  • Views 700 views
MarkSchmitt
MarkSchmitt over 2 years ago
I have AES-ACC-DPEMMC-G along with the ZuBoard 1CG, no matter which example I run or when I try to start X in Ubuntu, I get "no display" error. Do I need to play around switches or install some driver/package? Am I missing something? Please advise
  • fbt
    0 fbt over 2 years ago
    Hi Mark, as probably you, i´m still having a lot of problems for integrating these devices, since in my opinion, there is a lack of information and support from AVnet;) ... i still had not success in developing a baremetal application (i tried i.e. from xdpdma example with different configurations) for displaying anything on my DP monitor, since i always get a blank screen. The only way i got valid results was using petalinux. You can follow the project available in www.hackster.io/.../zuboard-building-the-foundational-designs-f114d5 for zub1cg_sbc_base foundational design (the USB camera is not required), and after the step in which you discover which IP address has been assigned to your ZUBoard and you connect to it via MobaXterm or any other SSH client, i.e. Putty (ensuring that you have X-11 forwarding enabled), follow the procedure you can find in the attached doc, just for testing the ZuBoard 1CG + AES-ACC-DPEMMC-G integration and the DP monitor setup. Try it and tell me if it works for you, and in case you make any advance in a functional baremetal application, i would really appareciate any feedback from you. Best regards.
