ZUBoard Vivado 2024.1 board_part definition errors when using the Avnet ZUBoard_1CG Development Board
  • Subscribers 345 subscribers
  • Views 1895 views
hw_engr
hw_engr over 1 year ago
Has anyone else gotten the following error message even though the board_part definition is available?  I am using Vivado 2024.1.
[Board 49-71] The board_part definition was not found for avnet.com:zuboard_1cg:part0:1.0. The project's board_part property was not set, but the project's part property was set to xczu1cg-sbva484-1-e. Valid board_part values can be retrieved with the 'get_board_parts' Tcl command. Check if board.repoPaths parameter is set and the board_part is installed from the tcl app store.
  • hw_engr
    hw_engr over 1 year ago in reply to bidrohini +2
    Thanks for the feedback. I have resolved the problem by moving the previously installed files to a different location. The original location had a space in the path which I believe was causing the problem…
  • hw_engr
    hw_engr over 1 year ago in reply to padudle +1
  • padudle
    0 padudle over 1 year ago
    I think that means you do not have the Avnet BDF files installed on your computer.  You can download a zip file from the Avnet github repository.  Then you have to copy the results into the correct folder inside your Vivado installation.  You will need administrator rights to do that.  Good luck.
    GitHub - Avnet/bdf: Avnet Board Definition Files
  • bidrohini
    0 bidrohini over 1 year ago
    I think the board definition files are incorrectly installed.
  • hw_engr
    0 hw_engr over 1 year ago in reply to padudle
    Thanks for the feedback.  I have resolved the problem by moving the previously installed files to a different location.  The original location had a space in the path which I believe was causing the problem.  However, I didn't take the time to do additional experiments to prove that was the problem.
  • hw_engr
    0 hw_engr over 1 year ago in reply to bidrohini
