ZUBoard Buildroot defconfig
  • Subscribers 363 subscribers
  • Views 1055 views
Buildroot defconfig
Ratin
Ratin over 1 year ago
Does anybody have a Buildroot & u-boot defconfig for the ZUB1CG rev 1 board?
  • padudle
    0 padudle over 1 year ago
    I don't know if this will help but I save my instructions for booting linux on the ZUBoard here:
    github.com/.../zuboard.git
  • Ratin
    0 Ratin over 1 year ago in reply to padudle
    Hi yes I am actually looking for buildroot defconfig whereas you have used Petalinux. But even petalinux based binaries did not work on mine so i may get some insight from your repo. thanks very much
  • Ratin
    Getting these errors (I am using Vivado 2022.1) :
    ****** Vivado v2022.1 (64-bit)
    **** SW Build 3526262 on Mon Apr 18 15:47:01 MDT 2022
    **** IP Build 3524634 on Mon Apr 18 20:55:01 MDT 2022
    ** Copyright 1986-2022 Xilinx, Inc. All Rights Reserved.
    source setup.tcl
    # close_project -quiet
    # file delete -force proj.xpr *.os *.jou *.log proj.srcs proj.cache proj.runs
    # create_project -part xczu1cg-sbva484-1-e -force proj
    # set_property target_language Verilog [current_project]
    # set_property default_lib work [current_project]
    # load_features ipintegrator
    # read_ip ../source/zmod_test/zmod_ila/zmod_ila.xci
    WARNING: [IP_Flow 19-395] Problem validating against XML schema: : Unexpected end of message
    INFO: [IP_Flow 19-234] Refreshing IP repositories
    INFO: [IP_Flow 19-1704] No user IP repositories specified
    INFO: [IP_Flow 19-2313] Loaded Vivado IP repository '/tools/2022.1/Vivado/2022.1/data/ip'.
    ERROR: [IP_Flow 19-8166] Failed to verify json document against the schema 'xilinx.com:schema:json_instance:1.0'.
    "additionalProperties": {
    "disallowed": "enabled",
    "instanceRef": "#/ip_inst/parameters/component_parameters/C_TIME_TAG_WIDTH/0",
    "schemaRef": "file:///param_value_v1_0.json#/definitions/param_value"
    CRITICAL WARNING: [IP_Flow 19-979] Failed to recreate IP instance 'zmod_ila'. Error setting original project options.
    WARNING: [Vivado 12-13651] The IP file '/proj/zub_hdlguy/source/zmod_test/zmod_ila/zmod_ila.xci' has been moved from its original location, as a result the outputs for this IP will now be generated in ''. Alternatively a copy of the IP can be imported into the project using one of the 'import_ip' or 'import_files' commands.
    ERROR: [Common 17-39] 'read_ip' failed due to earlier errors.
    while executing
    "read_ip ../source/zmod_test/zmod_ila/zmod_ila.xci"
    (file "setup.tcl" line 12)
    INFO: [Common 17-206] Exiting Vivado at Fri Nov 29 13:55:31 2024...
    source compile.tcl
    # open_project proj.xpr
    INFO: [filemgmt 56-3] Default IP Output Path : Could not find the directory '/proj/zub_hdlguy/implement/proj.gen/sources_1'.
    Scanning sources...
    Finished scanning sources
    ERROR: [Common 17-39] 'open_project' failed due to earlier errors.
    while executing
    "open_project proj.xpr"
    (file "compile.tcl" line 4)
    INFO: [Common 17-206] Exiting Vivado at Fri Nov 29 13:55:41 2024...
