ZUBoard Petalinux importing XSA fails
  • Subscribers 362 subscribers
  • Views 871 views
Ratin
Ratin over 1 year ago
After downloading the stock 2022.1 BSP and synthesizing the hdl from 2022.1 branch of the repo, as I tried to go thru building petalnux project it worked but importing the xsa fails:
Issued the command petalinux-config -v --get-hw-description /proj/zub/hdl/projects/zub1cg_sbc_base_2022_1/zub1cg_sbc_base.xsa
[INFO] Generating plnxtool conf
rsync: link_stat "/tools/2022.1/petalinux/components/misc/yocto_machines/zub1cg-sbc.conf" failed: No such file or directory (2)
rsync error: some files/attrs were not transferred (see previous errors) (code 23) at main.c(1196) [sender=3.1.2]
[INFO] Adding user layers
Why does this happen? Is it trying to create a new  conf file and fails?
The base folder exists"
1$ ls -la /tools/2022.1/petalinux/components/misc/yocto_machines
total 132
drwxrwxrwx 2 ratin ratin 4096 Nov 29 16:07 .
drwxrwxrwx 5 ratin ratin 4096 Apr 19 2022 ..
-rwxrwxrwx 1 ratin ratin 603 Apr 19 2022 avnet-digilent-zedboard.conf
-rwxrwxrwx 1 ratin ratin 497 Apr 19 2022 eval-brd-sc.conf
-rwxrwxrwx 1 ratin ratin 540 Apr 19 2022 xilinx-ac701.conf
-rwxrwxrwx 1 ratin ratin 547 Apr 19 2022 xilinx-k26-kr.conf
-rwxrwxrwx 1 ratin ratin 547 Apr 19 2022 xilinx-k26-kv.conf
-rwxrwxrwx 1 ratin ratin 546 Apr 19 2022 xilinx-k26-som.conf
-rwxrwxrwx 1 ratin ratin 540 Apr 19 2022 xilinx-kc705.conf
-rwxrwxrwx 1 ratin ratin 547 Apr 19 2022 xilinx-kcu105.conf
-rwxrwxrwx 1 ratin ratin 487 Apr 19 2022 xilinx-kcu105-tmr.conf
-rwxrwxrwx 1 ratin ratin 540 Apr 19 2022 xilinx-sp701.conf
-rwxrwxrwx 1 ratin ratin 851 Apr 19 2022 xilinx-ultra96-reva.conf
-rwxrwxrwx 1 ratin ratin 543 Apr 19 2022 xilinx-vck190.conf
-rwxrwxrwx 1 ratin ratin 561 Apr 19 2022 xilinx-vck190-sc.conf
-rwxrwxrwx 1 ratin ratin 550 Apr 19 2022 xilinx-vck5000.conf
-rwxrwxrwx 1 ratin ratin 592 Apr 19 2022 xilinx-vc-p-a2197-00.conf
-rwxrwxrwx 1 ratin ratin 547 Apr 19 2022 xilinx-vcu118.conf
-rwxrwxrwx 1 ratin ratin 543 Apr 19 2022 xilinx-vmk180.conf
-rwxrwxrwx 1 ratin ratin 567 Apr 19 2022 xilinx-vpk120-es1.conf
-rwxrwxrwx 1 ratin ratin 567 Apr 19 2022 xilinx-vpk180-es1.conf
-rwxrwxrwx 1 ratin ratin 479 Apr 19 2022 xilinx-zc1751-dc1.conf
-rwxrwxrwx 1 ratin ratin 534 Apr 19 2022 xilinx-zc702.conf
-rwxrwxrwx 1 ratin ratin 534 Apr 19 2022 xilinx-zc706.conf
-rwxrwxrwx 1 ratin ratin 543 Apr 19 2022 xilinx-zcu102.conf
-rwxrwxrwx 1 ratin ratin 543 Apr 19 2022 xilinx-zcu104.conf
-rwxrwxrwx 1 ratin ratin 543 Apr 19 2022 xilinx-zcu106.conf
-rwxrwxrwx 1 ratin ratin 543 Apr 19 2022 xilinx-zcu111.conf
-rwxrwxrwx 1 ratin ratin 550 Apr 19 2022 xilinx-zcu1275.conf
-rwxrwxrwx 1 ratin ratin 550 Apr 19 2022 xilinx-zcu1285.conf
-rwxrwxrwx 1 ratin ratin 543 Apr 19 2022 xilinx-zcu208.conf
-rwxrwxrwx 1 ratin ratin 543 Apr 19 2022 xilinx-zcu216.conf
-rwxrwxrwx 1 ratin ratin 543 Apr 19 2022 xilinx-zcu670.conf
  • Ratin
    0 Ratin over 1 year ago
    Should there be a custom machine .conf for zub1cg that should have been added in the meta-user layer but its not ?
    https://adaptivesupport.amd.com/s/question/0D54U00006AtBtQSAV/petalinux-20222-shows-rsync-error-when-yocto-machine-is-anything-custom?language=en_US
    When I clone petalinux git repo 2022.1 and run the build script make_zub1cg_sbc_base.sh, I get the same warning.
  • padudle
    0 padudle over 1 year ago in reply to Ratin
    It has been getting more difficult to achieve a stable Petalinux boot. The latest versions of the tools have introduced something they call the SDT Workflow.  I find that has even more bugs. Xilinx has lost the focus on regular industrial solutions and has gone AI crazy. Good luck.
  • dyessgg
    0 dyessgg over 1 year ago in reply to padudle
    Quality as a whole has degraded significantly since the AMD takeover.  They're being redirected to changing historic standard computer industry terms to new woke standards instead of actual quality.
